Date/Time: Tue, 21 Jan 2025 01:00:20 +0000
daily chart for 1 year are completely wrong, other data is fine
View Count: 804
[2018-07-18 16:24:02] |
samual sprat - Posts: 343 |
Hi, I have data from CTS and I have opened a historical daily chart with 5000 days loaded. The data between 06/17 and 06/18 is heavily skewed down as you can see in the image. I have enabled volume based rollover and have tried to delete and redownload data but cannot seem to fix it. Any ideas? http://www.sierrachart.com/image.php?Image=1531930880104.png Thanks S |
[2018-07-18 17:20:51] |
Follow the instructions here: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
