Date/Time: Tue, 21 Jan 2025 00:54:02 +0000
[Programming Help] - connection data
View Count: 671
[2018-07-18 11:41:23] |
User558452 - Posts: 9 |
HELLO whene I open my graph I get only the historical graph and not the reall time graph on my chartbook wy ?
[2018-07-18 16:47:13] |
You are using a CME Group exchange fee which requires a trading account. Refer to the instructions here to connect to your trading account: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#IntegrationWithTradingServices (Integration with Trading Services) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-18 16:47:25
