Date/Time: Tue, 21 Jan 2025 00:52:28 +0000
Grid Lines
View Count: 987
[2018-07-18 03:47:45] |
User223734 - Posts: 103 |
Dear Sir, Can I have Grid Lines background on the chart? |
[2018-07-18 17:10:44] |
Make sure this option is disabled: Chart Settings: Draw Horizontal/Vertical Grid Above Graphs (Chart >> Chart Settings >> Grid menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
