Date/Time: Mon, 20 Jan 2025 20:49:00 +0000
[User Discussion] - Visual Studio Community 2017 Installer Components/Add-ins
View Count: 1120
[2018-07-16 13:36:41] |
User92573 - Posts: 541 |
Dear Support I'd like to download Visual Studio Community 2017 however unlike my earlier installation I am now being offered numerous options. Please can you advise which of the Workload/Components/Add-ins I will need to install to work with ASCIL Custom Studies and build 32/64 DLL's. Many thanks. |
VS Community.png / V - Attached On 2018-07-16 13:35:56 UTC - Size: 35.31 KB - 274 views |
[2018-07-16 15:49:31] |
You need nothing more than the C++ compiler and Windows SDK support. This is all. No other components.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-16 15:49:55
