Date/Time: Sun, 20 Sep 2026 11:21:10 +0000
Sierrachart is not connecting to data.
View Count: 1183
[2018-07-16 11:58:04]
User377666 - Posts: 4
I have installed sierrachart on my new laptop but the platform is not connecting to data feed. Can you detect the problem?
Reading Internal Order ID file. | 2018-07-16 11:51:46
Reading Trade Orders file. | 2018-07-16 11:51:46
Reading Trade Positions and Account Balance file. | 2018-07-16 11:51:46
Listening on UDP port 22904. | 2018-07-16 11:51:46
Software version: 1776 64-bit | 2018-07-16 11:51:46
Usage end date: 2018-08-15 | 2018-07-16 11:51:46
Enabled for: Advanced Features. | 2018-07-16 11:51:46
Enabled for: Advanced Features 2. | 2018-07-16 11:51:46
Enabled for: Sierra Chart Historical Data Service. | 2018-07-16 11:51:46
Allow Support for Sierra Chart Data Feeds is enabled. | 2018-07-16 11:51:46
Current selected Data/Trading service: CQG WebAPI | 2018-07-16 11:51:46
Chart Update Interval: 500 | 2018-07-16 11:51:46
Time Zone: +00:00:00 (UTC+00) | 2018-07-16 11:51:46
2018-07-16 13:51:46 Local computer time | 2018-07-16 11:51:46
2018-07-16 11:51:46 Local computer time in UTC | 2018-07-16 11:51:46
2018-07-16 11:51:46 Local computer time in SC Time Zone | 2018-07-16 11:51:46
2018-07-16 11:51:46 Server time in UTC | 2018-07-16 11:51:46
Local computer UTC time and Server UTC time difference: 1 seconds. | 2018-07-16 11:51:46
Program path: C:\SierraChart\ | 2018-07-16 11:51:46
Data Files path: C:\SierraChart\Data\ | 2018-07-16 11:51:46
OS Version Number: 10.0 | 2018-07-16 11:51:46
Locale Setting: C | 2018-07-16 11:51:46
Checking for new symbol settings for service code cqg | 2018-07-16 11:51:46
HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-07-16 11:51:46
HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-07-16 11:51:46
Symbol settings are up-to-date for cqg | 2018-07-16 11:51:48
Received 5 login tokens. | 2018-07-16 11:51:48
HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2018-07-16 11:51:48
HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2018-07-16 11:51:48
HTTPS connection to login.sierrachart.com:443 (1) | Socket gracefully closed by remote side. | 2018-07-16 11:51:50
HTTPS connection to login.sierrachart.com:443 (1) | Initiating close of socket by core. | 2018-07-16 11:51:50
HTTPS connection to login.sierrachart.com:443 (1) | Received socket Close event. | 2018-07-16 11:51:50
HTTPS connection to login.sierrachart.com:443 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-07-16 11:51:50
HTTPS connection to login.sierrachart.com:443 (1) | Closed. | 2018-07-16 11:51:50
HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-07-16 11:51:53
HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2018-07-16 11:51:53
HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2018-07-16 11:51:53
HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-07-16 11:51:53
HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2018-07-16 11:51:53
HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-07-16 11:51:53
HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2018-07-16 11:51:53
HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2018-07-16 11:51:53
HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-07-16 11:51:53
HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2018-07-16 11:51:53
HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-07-16 11:51:54
HTTPS connection to www.sierrachart.com:443 (5) | Received socket Close event. | 2018-07-16 11:51:54
HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2018-07-16 11:51:54
HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-07-16 11:51:54
HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2018-07-16 11:51:54
CQG WebAPI | Connecting to server api.cqg.com | 2018-07-16 11:51:57
CQG WebSocket | Connecting to WebSocket server. | 2018-07-16 11:51:57
CQG WebSocket socket (6) | Creating socket. Using TLS 1.2. | 2018-07-16 11:51:57
CQG WebSocket socket (6) | Connecting to IP: 195.166.124.165. | 2018-07-16 11:51:57
CQG WebSocket | Opening WebSocket. | 2018-07-16 11:51:57
CQG WebSocket | Sending WebSocket handshake. | 2018-07-16 11:51:57
CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-07-16 11:51:57
CQG WebSocket | Header line. Connection: upgrade | 2018-07-16 11:51:57
CQG WebSocket | Header line. Sec-WebSocket-Accept: aQQptcTc7Gvy4Y9yj39eBFZN8VY= | 2018-07-16 11:51:57
CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-07-16 11:51:57
CQG WebSocket | Header line. Upgrade: websocket | 2018-07-16 11:51:57
CQG WebSocket | Header line. | 2018-07-16 11:51:57
CQG WebSocket | Web socket state is now open. | 2018-07-16 11:51:57
CQG WebAPI | WebSocket connected. | 2018-07-16 11:51:57
CQG WebAPI | Sending market data logon message. | 2018-07-16 11:51:57
CQG WebAPI | Market data logon unsuccessful. Server message: Username or password is incorrect. | 2018-07-16 11:51:58 *
CQG WebSocket socket (6) | Adding bytes from final send buffer from buffered socket: 8 | 2018-07-16 11:51:58
CQG WebSocket socket (6) | Initiating close of socket by core. | 2018-07-16 11:51:58
CQG WebSocket | WebSocket closed. | 2018-07-16 11:51:58
CQG WebAPI | WebSocket closed. | 2018-07-16 11:51:58
CQG WebSocket socket (6) | Sending bytes from final send buffer: 8 | 2018-07-16 11:51:58
CQG WebAPI | Disconnected. | 2018-07-16 11:51:58
CQG WebSocket socket (6) | Write in progress. Shutdown being delayed. | 2018-07-16 11:51:58
CQG WebSocket socket (6) | Write has completed. Shutdown being performed. | 2018-07-16 11:51:58
CQG WebSocket socket (6) | Shutdown started. Waiting for graceful close. | 2018-07-16 11:51:58
CQG WebSocket socket (6) | Socket gracefully closed by remote side. | 2018-07-16 11:51:58
CQG WebSocket socket (6) | Closed. | 2018-07-16 11:51:58
[2018-07-16 16:03:04]
This is the relevant message:
Refer to item 3 here:
CQG Trading Platform Service: Common Error Messages
