Date/Time: Mon, 20 Jan 2025 20:56:42 +0000
Bug report - changing fill price in the trade activity log
View Count: 570
[2018-07-16 10:06:15] |
BrMa - Posts: 80 |
Dear ladies & gentlemen, since Version 1781 there seems to be a bug with editing entries in the trade activity log. I'm trading F.US.FDXMU18 (the german mini-index DAX) on paper. The price is noted only in full values - so there are no digits after the comma. If I'm editing a trade (regardless if it is a "fill" or an "order") the entered price is extended by adding 8 zeros behind the comma and - more severe - the order is not shown any more in the chart, whereas the bracket-orders stay where they are... I assume the price cannot be interpreted correctly and therefore the order does not show up. If I restart SierraChart - the entered price is used correctly but any change results in the same behaviour described above. Can you please take a look into that? If you need a screenshot of the trade activity log, please let me know. Regards, Markus |
[2018-07-16 16:13:14] |
We are checking on this.
[2018-07-16 16:59:47] |
The reason for this is a very simple issue where the symbol when editing the trade activity entry should not have [Sim] in front of it for a simulated entry. We are putting out a new release now.
