Date/Time: Tue, 21 Jan 2025 00:45:00 +0000
slave Share file updating once master has updated
View Count: 939
[2018-07-16 05:27:35]
User651753 - Posts: 77
I have a few chartbook shares with my self. ( VPS to run 24/7)
when I have made changes to the master file from my home PC,
do I need to re-share that same chart book, or does my 2nd computer update the file? (once closed and reopen)
[2018-07-16 16:09:16]
Yes.
Here is an easy way to do this:
File Sharing
[2018-07-17 05:22:21]
I understand how to share, as I am currently sharing,
but when I change the spreadsheet. it doesn't update the new save setting to my share account . or to other that I have shared my chartbook and spreadsheet
[2018-07-17 18:41:09]
Would be best that you just manually copy the files. Refer to:
Chartbooks (Workspaces): Sharing a Chartbook with Another User or Copying it to Another Installation
Same procedure also applies to Spreadsheet files.
[2018-07-18 02:45:48]
yea, I tried running the whole app folder from Dropbox, which work quite well
Would be create if you had a better sharing/cloud backup
