Date/Time: Tue, 04 Nov 2025 18:08:39 +0000
No Replay window at all
View Count: 3156
| [2013-04-06 09:43:39] |
| LukasCh - Posts: 5 |
Hello support team, starting today, I am not able to launch replay mode / window at all. When I click on replay icon, or select it from Chart -> Replay Chart, nothing happens at all. Only main window became inactive. I've tried to restart Sierra, Restart windows, Update sierra to the last version - nothing happens. 2 day ago, it worked perfectly. Replay window doesnt work for any symbol or any data feed. Also, no errors in error log appears (but I am posting here error log) What am I doing wrong? Date Time Of Last Edit: 2013-04-06 19:23:09
| [2013-04-06 19:23:43] |
The Chart Replay window is off the screen. Select Window >>Reset Windows and open it again.
| [2013-04-07 09:19:27] |
Thank you.
