Date/Time: Mon, 20 Jan 2025 20:49:24 +0000
Save a chart to a specific date and time
View Count: 604
[2018-07-15 10:25:15] |
blknsxy - Posts: 29 |
How can I Save a chart to a specific date and time. so that after reopening or return following shut down.
[2018-07-16 16:07:19] |
No, this is not supported. The chart will always be at the end when reopening the Chartbook.
