Date/Time: Tue, 21 Jan 2025 00:49:09 +0000
CQG Order Changes Release 1778
View Count: 705
[2018-07-14 14:01:58] |
User360283 - Posts: 506 |
Dennis Curcio Jul 14, 7:02 AM CDT I currently use orders with a single target. Not OCO. Is this still supported and will it continue to be supported in the future. Can I install the current version? Thanks 1778 Release Date: 2018-07-05 [Link] - [Top] Support has been removed for CQG server-side bracket orders. If you need support for these types of orders, it is recommended to use the CTS low-cost connection model. Server-side OCO orders are still supported with CQG. You can also run an older version of Sierra Chart for continued support of them. There have been too many associated issues with CQG server-side bracket orders and we are no longer willing to support them as they cause problems for users and create a poor impression of Sierra Chart when the issue is not even on our side to begin with. |
[2018-07-14 15:33:32] |
I currently use orders with a single target. Not OCO. Yes. These are still supported as well as both a Target and Stop with server-side OCO. You can use the latest version.
Is this still supported and will it continue to be supported in the future. Can I install the current version? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-14 15:34:22
[2018-07-23 04:42:38] |
User184859 - Posts: 17 |
The answer given to this question contradicts the release notes for version 1778. Does this mean that in the end support for CQG server-side bracket orders was maintained?
[2018-07-23 04:57:57] |
In the latest prerelease we actually have restored support for CQG bracket orders. We made a small change which may resolve the problem we became aware of. We will be updating the version notes about this. However, there is a difference between server-side OCO and what we call server-side bracket orders. This is explained here: Attached Orders: Management of Attached Orders when Trading Service Supports Server Side OCO Only Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-23 04:58:17
