Date/Time: Mon, 20 Jan 2025 20:53:48 +0000
[User Discussion] - color background on TICK chart
View Count: 764
[2018-07-14 03:20:03]
Chuck6475 - Posts: 24
I have three tick chart on CL. 610,987,1597 ticks respectively.
I set up the 1597 chart first with studies (BB, EMA, MA, STOCHASTICS).
The color background was setup to test the Low price to be lower than lower BB and the high to be higher than the higher BB - and lower than 20 or higher than 80 on stochastics.
It works 98% of time on 1597 chart about 50% on 987 chart and not at all on 610 chart.
Is there an order the studies have to be in for it to work?
[2018-07-14 14:36:05]
http://www.sierrachart.com/image.php?Image=1531578553971.png
This should be a screen shot of 987 tick chart with the CVT values for the red candle in the center of the red circle.
This candle should have been highlighted like many of the other candles.
http://www.sierrachart.com/image.php?Image=1531578832367.png
This is the same chart converted to a 610 tick chart. There are no highlighted candles at all.
