Date/Time: Tue, 21 Jan 2025 00:55:44 +0000
Number Of Allowed Systems
View Count: 1096
[2018-07-13 21:06:54]
tamerbahey - Posts: 4
My inquiry about (Number Of Allowed Systems:2)
is that means that i can use Sierra charts platforms for two users (two users with different ip addresses)
and the two users can use data feed at the same time(I use CME globex data feed),
[2018-07-15 10:09:47]
When you refer to the CME data feed are you referring to real-time data?
[2018-07-22 19:08:47]
Yes I'm referring to real time data...is it possible for two users at the same time???
[2018-07-23 03:45:34]
The two users really should have their own separate Sierra Chart accounts. And if you want to use the Sierra Chart Exchange Data Feed for two different users:
each user definitely will need a separate account.
[2018-07-24 07:08:55]
Thanks...also please i have problem with Forex historical data,
my account historical data (GBP/USD) till December 2017 only for small time frames (Daily - 4 hours),
how can i get historical data before this time??
Appreciate your quick response
