Date/Time: Mon, 20 Jan 2025 20:47:11 +0000
Trading
View Count: 1705
[2018-07-13 16:17:53] |
Joseph Keller - Posts: 19 |
Hello, can I use Sierra Charts with E-Trade and/or Tastyworks and/or TD AMeritrade?
[2018-07-13 17:48:32] |
TD Ameritrade is supported. Refer to: https://www.sierrachart.com/index.php?page=doc/AmeriTrade.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-13 20:23:34] |
What about E-Trade and/or Tastyworks ?
[2018-07-13 21:03:16] |
Xfanman1 - Posts: 320 |
Joseph, they answered your question. TDAmeritrade is supported. Since they didn’t mention that E-Trade and TastyTrade are supported also, would you not conclude that they are not? (They aren’t). — Scott |
[2018-07-13 22:00:44] |
Scott, why would I assume that they did not answer my question? To assume is poor communication. You/they could have simply missed that part.
[2018-07-14 15:43:35] |
Only TD Ameritrade is supported among the specified services.
