Date/Time: Mon, 20 Jan 2025 20:48:44 +0000
Historical/Intraday Data not complete
View Count: 667
[2018-07-13 12:20:03] |
mpho lesufi - Posts: 2 |
Hello, I seem to be having a problem loading complete chart data (historical/intraday) on NZDUSD and AUDUSD pairs; specifically for 1 and 4 Hour Charts. I only see the last2 weeks and not more. On the other hand Daily Time frame and above are okay. All other pairs are okay What could be issue? Im using SC FX data (FXCM. ) Thank you |
[2018-07-13 12:46:50] |
Follow the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-13 13:34:10] |
Thank you. seems to be working.
