Date/Time: Mon, 20 Jan 2025 20:48:09 +0000
Add "Range" to Quoteboard
View Count: 708
[2018-07-12 17:21:35] |
infpz - Posts: 826 |
Possible to add a simple field for the High/Low range (i.e. High - Low) to the supported fields for the Quote Board?
[2018-07-13 14:18:23] |
Yes we can do this. It will be out in the next release.
