Date/Time: Mon, 20 Jan 2025 20:46:59 +0000
SP advances
View Count: 698
[2018-07-12 16:25:04]
User28682 - Posts: 233
Im trying to take the difference between SP 500 advances - SP500 declines, then sum up the last 5 days of this difference and plot. Can anyone help with this?
(ADV-SP) - (DECL-SP) =day1
(ADV-SP[1]) - (DECL-SP[​1​]) =day2
(ADV-SP​[2]​) - (DECL-SP​[2]​) =day​3​
(ADV-SP​[3]​) - (DECL-SP​[3]​) =day​4​
(ADV-SP​[4]​) - (DECL-SP​[4]​) =​​day​5​
(day​​1 + ​day​2 + ​day​3​ + ​day​4 + ​day​5​) = "X"
Then plot "X"
Thank you!!
[2018-07-16 17:13:43]
I am confused why I cant get a response from someone on this question? Is there a problem with you?
[2018-07-16 17:18:10]
This is normally not within the scope of our support and that is why we have not responded and we did see your email in regards to this as well. But we can certainly give you some guidance on it.
But you should be able to do this though by using the Arithmetic Studies:
Using the Basic Arithmetic Studies
For example use Study Subgraphs Subtract to do the difference.
And use the Spreadsheet Formula study for the rest of the calculation:
Spreadsheet Formula
Date Time Of Last Edit: 2018-07-16 17:19:41
