Date/Time: Sun, 24 Nov 2024 08:46:49 +0000
import symbol list from excel
View Count: 1727
[2013-10-16 17:57:10] |
User70302 - Posts: 30 |
Is there a way to import a symbol list from excel to SC (eg. into the quoteboard) so that I can easily scroll through the respective charts after the import? |
[2013-10-16 21:28:42] |
Yes. As long as the symbols are in a text file. Refer to the instructions here: https://www.sierrachart.com/index.php?l=doc/doc_GettingQuotes.html#SavingLoadingImportSymbolList Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
