Date/Time: Sun, 24 Nov 2024 09:45:45 +0000
Rockwell Template SC.cht
View Count: 1913
[2013-10-16 17:51:57]
User36544 - Posts: 5
Hi There,
I am finding one of the recent additions to Sierra Chartbooks, titled "Rockwell Template SC" to be MOST effective when trading the existing default symbols ie. ES, GC, 6E, YM, CL, ZB.
The problem I am having is that when I change symbols on a chart or try to add a new chart to include additional the ADR, Stop Loss and Profit Target values that are displayed all revert to a 0.00 value. Can you please assist in overcoming this issue?
I know there is an older 'Rockwell Chartbook' which I also have, but I prefer the latest one - I am looking for instructions on how to use and maintain newer "Rockwell Template SC" Spreadsheet?
Hoping you can help.
[2013-10-16 18:04:37]
sorry...that should have read:
The problem I am having occurs both when adding a new chart or changing existing chart to a symbol other than the default. ie. 6A, NQ, etc
[2013-10-17 00:57:08]
The problem is we are not familiar with that Chartbook. We can help to add new charts to the existing Chartbook found here:
http://www.sierrachart.com/index.php?l=doc/AdditionalFiles.php
[2013-10-20 09:06:48]
The chartbook you have referred me to I already have. I thought it relevant to mention this as a final point to my enquiry in the hope that you would not refer me to a chartbook that I already have.
Secondly, the new and improved chartbook that you are not as yet familiar with is the newest improves default chartbook included with Transact, Infinity and Sierra Chart setup files (all downloaded from this very supportboard). Again the name is'Rockwell Template SC' and has been available since early September. Can I suggest that you familiarise yourself with it and advise if there is a work around to issue raied in my initial enquiry.
Thank you.
Migs
Date Time Of Last Edit: 2013-10-22 01:36:56
[2013-10-23 18:41:10]
This is a specialized request which is outside the scope of our support. We had a quick look at the Chartbook, it is too involved with all of the studies for us to take the time with it.
Date Time Of Last Edit: 2013-10-23 18:42:08
