Date/Time: Mon, 20 Jan 2025 20:51:37 +0000
[User Discussion] - hello
View Count: 819
[2018-07-11 19:24:13]
User558452 - Posts: 9
Hello
i look for the classique stochastic
which one to choose
stochastic fast
stochastic slow
kd-fast
kd-slow
stochastic percentil
stochastic rsi
stochastic momentum indicateur
double stochastic bressert
[2018-07-11 22:07:11]
Xfanman1 - Posts: 320
I overlay 2 Slow Stochastics to achieve what I need. The "Standard" depends on what your needs are but The Slow or Fast Stochastic are pretty typical. I've turned on the settings in the attachment so you can see what my settings are but you need to use what is fitted to the time frames you trade in.
Scott
imageStochastic.PNG / V - Attached On 2018-07-11 22:06:59 UTC - Size: 38.12 KB - 407 views
[2018-07-12 22:34:21]
look Good
