Date/Time: Mon, 20 Jan 2025 20:48:19 +0000
Use of Sierra Chart for Equity Stock
View Count: 1668
[2018-07-11 16:32:41] |
User436940 - Posts: 23 |
Can you advise steps to integrate the use of Sierra Charts for Equity as I am currently able to use it for futures only? Will that involve creating a different chart-book? If yes, can you advise the process of combining the existing charts on futures with that of equity?
[2018-07-11 22:50:15] |
You just need to install another copy of Sierra Chart. If you just require historical data, set it to use the Sierra Chart Historical Data Service. Refer to the instructions here: Sierra Chart Historical Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
