Date/Time: Mon, 20 Jan 2025 20:57:59 +0000
[Programming Help] - Is there any way let spreedsheet to read drawing line value?
View Count: 700
[2018-07-11 15:53:56] |
User273940 - Posts: 1 |
Can I using spreedsheet to read drawing rectangle's value into spreedsheet formula? thanks Rex |
[2018-07-11 18:12:05] |
No, this is not supported.
