Date/Time: Mon, 20 Jan 2025 20:53:06 +0000
Specific chart wont pan
View Count: 673
[2018-07-11 12:13:18] |
canyiah - Posts: 48 |
I have several charts in a chartbook and only certain charts will pan using the hand tool is there a setting that changes individual charts settings to not pan?
[2018-07-11 15:03:58] |
Are you referring to horizontal or vertical movement?
[2018-07-11 16:29:06] |
yes i think i figured it out i did a reset scales and that seems to have worked
Date Time Of Last Edit: 2018-07-11 16:32:09
