Date/Time: Thu, 24 Sep 2026 03:52:24 +0000
[Programming Help] - spreadsheet index question
View Count: 1438
[2018-07-10 21:23:48]
joer - Posts: 41
I am trying to search for the first non-zero value in a column of numbers (a7:a19) that is not ordered. In Excel I use the following formula and it returns the result I am looking for:
=INDEX(A7:A19,MATCH(TRUE,INDEX(A7:A19<>0,),0))
When I enter this in the new spreadsheets, it returns #ARGS!
This used to work in the old spreadsheets. Can you provide the equivalent formula for new spreadsheets? Thank you.
[2018-07-11 00:18:45]
Sawtooth - Posts: 4354
Try this:
Use a spare column to create a T/F for the non-zero value in column A, e.g.: cells B7:B19
=A7<>0
(Copy/paste formula in column B so that the row increments).
Then use INDEX(... MATCH(... to return the first non-zero value in A7:A17
=INDEX(A7:A19,MATCH(1,B7:B19,0),1)
