Date/Time: Mon, 20 Jan 2025 20:47:35 +0000
Move stop to breakeven after target 1 is hit?
View Count: 1074
[2018-07-10 13:59:00] |
User66360 - Posts: 81 |
how do I create an OCO to move stop to breakeven after target one is hit?
[2018-07-11 08:50:50] |
We will work on documentation example for this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-11 08:51:00
[2018-07-13 12:47:48] |
Refer to the documentation here for this: Attached Orders: 2 Targets and Common Stop with Move to Breakeven on First Target Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-13 13:25:08] |
Thanks, I will check it out.
