Date/Time: Mon, 20 Jan 2025 20:56:19 +0000
System error
View Count: 639
[2018-07-10 07:57:27] |
User344826 - Posts: 1 |
http://www.sierrachart.com/image.php?Image=1531209211792.png Hi. I have been using the Ian Williams Index Trading Wizard successfully since I installed last Wednesday with multiple trades activating. As of yesterday (Monday) on both my home and work PC there are now next to no trades showing and the one that did activate (as per screenshot) doesn't show stop loss etc. I have updated the software and it does show all history as being updated. Hope you can help. Cheers John |
[2018-07-10 09:04:57] |
You need to contact them about this: Ian Williams Index Trading Wizard
This is functionality provided by them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
