Date/Time: Mon, 20 Jan 2025 20:53:03 +0000
CapTrader (IB offshot) supported by Sierra Chart?
View Count: 2003
[2018-07-10 06:57:12]
CaptainKirk - Posts: 2
is it possible to connect Sierra Chart to the broker "CapTrader" (https://www.captrader.com/en/)? CapTrader is a offshot of Interactive Brokers LLC and also works with the TWS. Should I simple use the Connection-Guide for IB-Accounts (Interactive Brokers Trading Service)?
I also would like to know, if a funded CapTrader account is qualified to use the CME futures data at the reduced exchange fees.
Thank you for your help and best regards
Alexander Kirk
[2018-07-10 09:06:25]
If that broker uses Interactive Brokers Trader Workstation, then yes it is supported. Just follow the setup instructions here:
If the answer to the above is yes, then this is yes as well.
[2018-07-16 07:49:30]
@other CapTrader customers: I set it up. It works absolutely fine. Thank you, SC.
