Date/Time: Sun, 24 Nov 2024 08:54:42 +0000
One Dom two brokers
View Count: 1452
[2013-10-16 16:07:54] |
JamesP - Posts: 89 |
Hello, I'm wondering if I can trade from one dom and have orders sent to CTS T4 and Interactive Brokers. Thanks. Jim |
[2013-10-16 19:07:22] |
No. You need to install 2 separate copies of Sierra Chart: https://www.sierrachart.com/index.php?l=doc/MultipleServices.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-10-17 14:42:27] |
Thanks for the response. I'm aware of the multiple copy set up. I currently run two copies. Just to clarify what I'm asking. Say if I had a dom open for two services, is there a way to send a single order to those two doms? If not have you considered this for a future build? For the record, I'm very happy with seirra, great platform. Thanks for your time. Jim |
[2013-10-17 18:33:50] |
No. This is not supported. And there are no plans for this. It is too complicated.
