Date/Time: Mon, 20 Jan 2025 20:58:37 +0000
candle wick colors
View Count: 2996
[2018-07-09 15:00:02] |
User635423 - Posts: 51 |
Is it possible to change the wick color of a candle? If so, how do I do this? Thanks |
[2018-07-09 15:52:01] |
Xfanman1 - Posts: 320 |
You can change the outline color easily but it will also change the candle border color. You can do that in the Graphics Settings under the Global or Chart menus. -- Scott |
Attachment Deleted. |
[2018-07-09 22:49:02] |
Yes this is explained in detail here: Graphics Settings: Independent Coloring and Widths for Candlesticks High-Low Bars (Wicks) Also refer to: Graphics Settings: Colors and Widths Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-09 22:49:32
