Date/Time: Mon, 20 Jan 2025 20:58:01 +0000
CHART DOM
View Count: 665
[2018-07-08 04:43:25] |
Trader&Hunter - Posts: 131 |
How do I change the chart dom to see each price tick instead of it skipping ticks. comparable to the regualar DOm?
Capture.PNG / V - Attached On 2018-07-08 04:42:16 UTC - Size: 24.31 KB - 276 views |
[2018-07-08 07:12:39] |
This is controlled through this Scale setting: Chart Scale and Scale Adjusting: Scale Increment (Scale Settings) (Scale Increment) And refer to: Chart Scale and Scale Adjusting: Opening the Scale Settings Window for the Main Price Graph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-08 07:13:05
