Date/Time: Sun, 24 Nov 2024 08:40:09 +0000
Time stamp and computer clock errors.
View Count: 1235
[2013-10-16 14:40:06] |
User23815 - Posts: 210 |
I am using IQ data feed and IB for trading. I constantly get a timestamp error letting me know that some things might not funtion correctly. I also received a message that my computer clock was off by 30 seconds. I usually go and try to update my internet time when I get either message. Often the computer won't update, saying there is an error. What is this issue and how can I correct it? Thanks |
[2013-10-16 16:29:50] |
Refer to these help topics: Http://www.sierrachart.com/index.php?l=doc/helpdetails38.html http://www.sierrachart.com/index.php?l=doc/helpdetails63.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
