Date/Time: Mon, 20 Jan 2025 17:05:54 +0000
new CB not saving
View Count: 621
[2018-07-06 00:04:30]
Pavel2 - Posts: 21
Hello I can't save my new CB. Here is my Message Log. The last line is the one that shows upon when I try to save my CB. Thank you for your answer. Pavel
Reading Internal Order ID file. | 2018-07-05 16:53:24
Reading Trade Orders file. | 2018-07-05 16:53:24
Reading Trade Positions file. | 2018-07-05 16:53:24
Listening on UDP port 22904. | 2018-07-05 16:53:24
Software version: 1713 32-bit | 2018-07-05 16:53:24
Usage end date: 2019-03-13 | 2018-07-05 16:53:24
Enabled for: Advanced Features. | 2018-07-05 16:53:24
Enabled for: Sierra Chart Historical Data Service. | 2018-07-05 16:53:24
Allow Support for Sierra Chart Data Feeds is enabled. | 2018-07-05 16:53:24
Current selected Data/Trading service: GAIN Capital/OEC | 2018-07-05 16:53:24
Chart Update Interval: 900 | 2018-07-05 16:53:24
Time Zone: -06:00:00 (MST-07MDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2018-07-05 16:53:24
2018-07-05 16:53:24 Local computer time | 2018-07-05 16:53:24
2018-07-05 22:53:24 Local computer time in UTC | 2018-07-05 16:53:24
2018-07-05 16:53:24 Local computer time in SC Time Zone | 2018-07-05 16:53:24
2018-07-05 22:53:23 Server time in UTC | 2018-07-05 16:53:24
Local computer UTC time and Server UTC time difference: 0 seconds. | 2018-07-05 16:53:24
Program path: C:\SierraChart\ | 2018-07-05 16:53:24
Data Files path: C:\SierraChart\Data\ | 2018-07-05 16:53:24
OS Version Number: 10.0 | 2018-07-05 16:53:24
Locale Setting: C | 2018-07-05 16:53:24
Error opening Chartbook file for writing. C:\SierraChart\Data\GC/SI .Cht Error: Windows error code 3: The system cannot find the path specified. | 2018-07-05 17:40:33 *
Error opening Chartbook file for writing. C:\SierraChart\Data\GC/SI .Cht Error: Windows error code 3: The system cannot find the path specified. | 2018-07-05 17:49:13 *
Date Time Of Last Edit: 2018-07-06 07:47:15
[2018-07-06 07:46:49]
You cannot use a / in a Chartbook file name. Remove that.
