Date/Time: Mon, 20 Jan 2025 20:46:43 +0000
Numbers Bars - Color Background Based On Numbers Percentage - For Session ONLY
View Count: 1133
[2018-07-05 21:31:30] |
User45989 - Posts: 54 |
Can anyone show me how to limit the calculation for the sub-graph "Color Background Based On Numbers Percentage" to the current session only? It appears to color the background based on the entirety of the data loaded for the chart and this is extremely frustrating. This makes the feature useless. The same thing happens with the "Numbers Bars Calculated Study". If anyone can show me how to limit it, I would be very grateful. thank you |
[2018-07-06 01:33:02] |
Acro - Posts: 441 |
I only care about it for NBCV so what I do there is limit the chart to load 1 day only (in chart settings) and ensure the session times are relevant to what I consider to be the session I am trading.
[2018-07-06 18:22:04] |
As Acro stated, the only way to limit the range of data in which the coloring of the Numbers Bars Calculated Values background is performed, is by limiting the Session Times. Refer to: Chart Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-06 18:23:53
