Date/Time: Mon, 20 Jan 2025 20:58:36 +0000
brower-based SC
View Count: 861
[2018-07-05 17:38:10] |
User565364 - Posts: 10 |
Hi do you have any plans to offer a browser-based version? Tradingview, CQG M are 2 examples I can think of Thank you |
[2018-07-05 17:41:22] |
Yes but this is going to be quite simplified. It will be a very simplified quote board, JavaScript based chart (not developed by us) and order entry. In general, Sierra Chart cannot be made web-based and never will. Such a concept makes utterly no sense and it would never work anyway. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-05 17:41:41
[2018-07-06 20:03:06] |
User75002 - Posts: 117 |
Hello, Do you have an estimated date on when this will be available? Will it be integrated with the CTS low-cost model so that the server-side bracket OCO orders on your servers can be managed remotely? |
[2018-07-06 20:57:17] |
The intention is that it should be sometime this year but the way it is going to work is that it will connect to your Sierra Chart which is running on your home computer or wherever. That is the only way that it can work with the type of connections Sierra Chart uses. The CTS low-cost connection model could be an exception and use direct connections from the browser, but we have to have a consistent model for this feature at least at first. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-06 20:57:54
