Date/Time: Mon, 20 Jan 2025 16:57:00 +0000
Using Sierra Chart with package 3 from AMP Futures
View Count: 2020
[2018-07-05 17:28:52] |
User709608 - Posts: 1 |
Hi. I use Sierra Chart, with Sierra Chart login account but with AMP CQG datafeed. Do I need to pay for Sierra Chart? Because AMP said it is included with my account. Also what is the difference between AMP Sierra Chart and stand alone Sierra Chart? Thanks |
[2018-07-05 21:06:44] |
Because AMP said it is included with my account. If this is what they say, then that is correct. Also what is the difference between AMP Sierra Chart and stand alone Sierra Chart? Primarily the difference is that you can only connect to your AMP brokerage account.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-05 21:06:55
