Date/Time: Mon, 20 Jan 2025 16:50:02 +0000
High/Low for time period
View Count: 817
[2018-07-04 18:05:11] |
User170575 - Posts: 221 |
Hi---the results for the study--High/Low for time period display on the chart but not the spreadsheet. Is there a work around besides building it into the spreadsheet? many thanks, Cy |
[2018-07-04 19:24:04] |
Refer to: Using the Spreadsheet Study: Solving Study Not Displaying On Spreadsheet Sheet Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-04 20:31:20] |
It appears the issue is using the Spreadsheet for Alert vs Trading. Thanks |
[2018-07-04 20:40:28] |
No, this could not be the issue. You need to check the settings as the documentation here explains: Using the Spreadsheet Study: Solving Study Not Displaying On Spreadsheet Sheet Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-04 20:40:36
