Date/Time: Mon, 20 Jan 2025 16:54:00 +0000
latest bar not updating
View Count: 551
[2018-07-04 00:57:05] |
AlgoTraderX - Posts: 3 |
Hi the price is changing but the candlestick is not updating, what should I do, thanks.
[2018-07-04 02:51:45] |
Xfanman1 - Posts: 320 |
Are you sure your Chart is all the way to the right edge? Is the number in the lower right corner of your chart green or red? — Scott |
[2018-07-04 04:11:34] |
Wow now I feel like a real n00b.Thanks.
[2018-07-04 05:50:15] |
Refer to help topic 3: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-04 05:50:17] |
