Date/Time: Mon, 20 Jan 2025 16:49:00 +0000
coloring inside bar differently
View Count: 969
[2018-07-04 00:31:01] |
User459170 - Posts: 262 |
Hi, is there a way to color bull and bear bars that are inside bars differently. The Inside bar study colors both bull and bear bars the same color, is there a way to differentiate between the two.
[2018-07-04 06:01:26] |
Yes, just create your own custom formulas to do what you need and use two instances of the Color Bar Based on Alert Condition study: https://www.sierrachart.com//index.php?page=doc/StudiesReference.php&ID=245&Name=Color_Bar_Based_on_Alert_Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-04 06:01:50
