Date/Time: Mon, 20 Jan 2025 16:59:36 +0000
horizontal grid and others
View Count: 877
[2018-07-03 00:51:04] |
User19467 - Posts: 5 |
Hi, I have created all the levels within the horizontal grid studies and saved it as the default BUT when I go to another chart it does not load it as created and saved as default. I have problems with other studies doing the same thing. I have read the instructions on the forum and sierra chart instructions to save as default.....to no avail. please help Thank you |
[2018-07-03 07:51:55] |
Specifically what are you doing? Saving Study Settings as a default is not going to have any affect upon existing instances of the study on charts.Perhaps you are interested in Chart Studies linking: Working With Charts: Chart Linking Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-03 07:52:05
[2018-07-03 14:05:20] |
Specifically what I am doing is add horizontal grid to chart I have changed all the colors line style with the labels, after all those changes I click on save as default, press apply then ok... I then go to a new chart and try to add the horizontal grid to that chart but all the settings are never saved, it has reverted back to the original default. |
horizontal grid.PNG / V - Attached On 2018-07-03 13:46:45 UTC - Size: 207.29 KB - 277 views |
[2018-07-03 15:55:55] |
It is hard for us to provide an answer because that is not a Sierra Chart provided study. It is provided by another user.
