Date/Time: Mon, 20 Jan 2025 17:02:58 +0000
Horizontal Line in all charts
View Count: 1066
[2018-07-02 21:26:16] |
User782160 - Posts: 1 |
Hi How can I place an horizontal Line, that appears in all charts of the same Future Contract? To make a definition of selected price levels. Regards Jose. |
[2018-07-05 07:16:17] |
Use the Horizontal Line tool to draw the line on one chart. Then on the other charts use the option under Chart >> Chart Settings >> Advanced Settings 2 >> Copy Chart Drawings From Chart #s. The documentation for this is here: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
