Date/Time: Tue, 21 Jan 2025 00:51:29 +0000
Out of bounds array.
View Count: 1310
[2018-07-02 18:37:01] |
User731023 - Posts: 138 |
Hi, I have been getting this message lately. Please instruct what I should do if possible. Thank you |
Attachment Deleted. |
[2018-07-05 16:02:37] |
Hi, If you get a chance. Thanks |
[2018-07-05 16:51:28] |
Update to the latest "Prerelease" and see if you still notice this: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-09 17:22:10] |
User104854 - Posts: 457 |
I've noticed this too recently. I just downloaded the 1779 pre-release this morning and I still see this error. I believe it is tied to the large volume trade indicator as I've just started using it and the times at which it is occurring match times where it generates a signal. Although at the beginning of the error message it says 'Color Bar Based on Alert Condition' but it doesn't say which study it is. Can you help?
[2018-07-09 19:27:26] |
If this happens with a particular Chartbook, then provide us that Chartbook following these instructions and we will test: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-12 15:49:40] |
Hi, Will do what is suggested above. I do believe it ties in with the Add additional symbol. When I enable it I got the post. (Out of bounds...) |
[2018-07-18 12:55:02] |
SC, Just wanted to let you know that I downloaded Pre-release 1781 and have not had a problem with freeze or array since. Thanks PS Will post if I do :oP |
