Date/Time: Mon, 20 Jan 2025 16:56:42 +0000
chart bars not updating real time
View Count: 797
[2018-07-02 16:45:22] |
dtl-saw - Posts: 79 |
I'm using IB for data The chart bars are not forming in real time. I know this because I have a chart price ladder on the chart and can see the price ladder bid/ask/last. The last on the price ladder can be as much as 5 or 10 seconds delayed before it updates the price bar on the chart. Does this sound like a familiar issue to you? Is there something I need to change in my settings to get the chart bars to update in realtime with IB data? Previously I was using SC real time data with no issues on the chart bars forming real time. I just switched over to IB real time data this morning and am seeing this issue for the first time. I only have one copy of SC running and the IB TWS, that's it no other software running on my computer. |
[2018-07-02 17:16:38] |
Refer to: https://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php#TrueRealTimeData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-02 17:23:23] |
Record True Real-Time Data was the problem - I had it enabled and that pauses bar updates 5 sec Thanks for providing the link |
