Date/Time: Thu, 17 Sep 2026 17:31:19 +0000
[Programming Help] - SCInputRef variable question...
View Count: 947
| [2018-07-02 16:30:32] |
| User895355 - Posts: 57 |
Basically, I want to increment MyVar by 1 each time "myCondition" is met. Works fine, except when I reload/recalculate the chart, MyVar does NOT reset to 0, keeps its value, and increments every time I reload/recalculate the chart. What am I missing here? I have this: SCInputRef MyVar = sc.Input[0]; if (sc.SetDefaults) { sc.AutoLoop = 1; MyVar.SetInt(0); return; } if (myCondition) { MyVar.SetInt(MyVar.GetInt() + 1); } |
| [2018-07-09 19:20:02] |
Ok, well, I'll answer my own question in case someone else has this issue (please correct if there's another way): if (sc.IsFullRecalculation)
{ if (sc.Index == 0) { MyVar.SetInt(0); } } |
| [2018-07-09 22:46:28] |
Yes the way you did it in the last post is correct.
