Date/Time: Wed, 16 Sep 2026 15:08:06 +0000
[User Discussion] - User contributed studies ECIVwapanchor1.4 question
View Count: 4593
[2018-07-02 16:25:09]
User786248 - Posts: 25
Hi
How do I edit or view the source code for the following user-contributed study? I would like to use the mouse anchoring function to create a new indicator I will be using but would like to know how he is using it in his code
THanks
[2018-07-03 12:56:58]
wwwingman - Posts: 185
https://www.sierrachart.com/AdditionalFiles/UserContributedACS_SourceCode/ECIVwap.cpp
[2018-07-05 18:35:14]
Hi wwwingman
I need some help in creating an indicator using your mouse anchoring function that you use in your ECIvwapAnchor Indicator. Can you accept my DM request? thanks
[2018-07-05 20:00:37]
Accepted.
[2020-04-03 01:25:02]
User488241 - Posts: 44
Was trying to build the ecivwapanchor.cpp in sierracharts but it looks like they've changed some variables and it's getting errors in compilation. I tried changing the persistvars to getpersistantint(1) but I'm not a coder and it's coming up with some issues. Please see the errors below. I will also put a copy of the code I tried to change but honestly if someone could update the user contributed studies text to reflect the change in variables I would really appreciate it instead of trying to scour through what I changed.
Thank you!
- Starting remote build of Custom Studies Source files: AnchoredVwap.cpp. 64-bit -- 21:18:12
Allow time for the server to compile the files and build the DLL.
The remote build did not succeed. Result:
AnchoredVwap.cpp: In function 'void scsf_ECIVwapAnchor(SCStudyInterfaceRef)':
AnchoredVwap.cpp:1043:30: error: 'struct s_sc' has no member named 'GetPersistent'
float& _higherHigh = sc.GetPersistent(f1);
AnchoredVwap.cpp:1043:44: error: 'f1' was not declared in this scope
AnchoredVwap.cpp:1044:28: error: 'struct s_sc' has no member named 'GetPersistent'
float& _lowerLow = sc.GetPersistent(f2);
AnchoredVwap.cpp:1044:42: error: 'f2' was not declared in this scope
AnchoredVwap.cpp: In function 'void ECIVwap_ComputeChannelVPOC(SCStudyInterfaceRef, unsigned int, SCSubgraphRef)':
AnchoredVwap.cpp:1610:34: error: 'class c_VAPContainer' has no member named 'GetVAPElementForPriceTickAndBarIndex'
if ( sc.VolumeAtPriceForBars->GetVAPElementForPriceTickAndBarIndex(_barIndex, _priceInTicks, &_p_vap) )
-- End of Build -- 21:18:15
Code I'm compiling
//SCDLLName DO NOT REMOVE
This program includes : ECIVwap ECIAnchorVwap and ECIVwapChannel
Developped by Emmanuel Chriqui (aka wwwingman).
Contact : ecivwap@chriqui.name
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/gpl.txt
The ECIVwap computes Volume Weighted Average Price for Daily/Weekly/Monthly/Quarterly/Yearly periods, and draws extensions of previous periods.
Vwap computation tries to be as accurate as possible since using volume at all prices in each bar, and is compatible with Sierra Vwap when using "Base on Underlying Data" option.
This is also true for the standard deviation calculation.
The ECIAnchorVwap uses Vwap computation algorithm, but the start and end dates are can be set in different ways (manually, automatically, at major reversal points, etc.).
The ECIVwapChannel uses Vwap computation algorithm, but draws a vwap channel of a user based period number of bars.
The ECIVwapBracket uses Vwap computation algorithm, and draws a vwap until price breaks out of bottom/top levels 4 (excess levels).
Changelog
V1.4 :
* Change : all studies name start with ECIVwap for clarity
* Enhance : add input only computation mode to all studies (no volume per price)
* Enhance : add SetAllColors to ECIVwap
* Enhance : add vpoc drawing to ECIVwapChannel (experimental)
* New : added ECIVwapBracket, an automatic way to draw vwap brackets (experimental)
* Maintenance : major code cleanup factoring and studies options harmonization
V1.3 :
* Fix ECIVwapChannel : start drawing stdev on period (was on first bar).
V1.2 :
* New indicator : ECIVwapChannel. draws a vwap channel of a user based period number of bars.
V1.1 :
* Fix : wrong vwap on bars with no volume (thin markets/renko..).
* Misc : removed version from DLL name.
V1.0 :
* Minor : changed default colors to light blue
* Maintenance : code cleanup, filled sierra description fields
* Misc : Distribution of code to Sierra Chart user contributed studies.
V0.10 :
* Enhance AnchorVwap : start date modes : manual (mouse anchoring), on higher high, on lower low, on last closed bar
* Fix AnchorVwap : when duplicating chart, manual mouse anchoring was not possible (hidden menu)
V0.9 :
* Enhance AnchorVwap : added 2 end date modes : end on previous bar, end on start bar.
* Fix : AnchorVwap was inefficient under some conditions and too heavy for CPU. Rolled back and fixed code.
V0.8 :
* Enhance AnchorVwap : replaced manual start date with contextual menu anchoring
* Enhance AnchorVwap : new option : set all colors automatically
* Enhance Vwap : 4 extension bands to Vwap instead of 2.
* Change Vwap & AnchorVwap : default multiplier is now 0.5
* New : GPL licence in code
* Maintenance : AnchorVwap code simplification and cleanup.
V0.7 :
* Fix : Wrong vwap calculation on very heavy volume bars (ex:ES monthly/quarterly bars..).
* Enhance : 4 extension bands to AnchorVwap instead of 2.
* Minor : default multiplier is now 0.5 (was 1).
V0.6 :
* Enhance AnchorVwap : 4 modes, continuos, end on date, end on higher high, end on lower low
* Fix : removed continous contract start date input from ECIVwap
* Minor : Range scale default is now same as region
V0.5 :
* Change : replaced ECIVwap continuous contract with new study
* New : added ECIAnchorVwap study, a continuous period vwap with start and end period, and an extension option.
* Enhance : draw study under main price
* Maintenance : code cleanup and factoring.
V0.4 :
* Enhance : Full compatibility with Sierra Vwap
* Bug fix : Quaterly vwap was broke in V0.3
* Enhance : better compatibility spreadsheet tests (had false positive related to floating point calculation)
V0.3 :
* Enhance : On intraday charts, Vwap period start on session beginning for daily and weekly vwaps
* Maintenance : code cleanup.
* Maintenance : compatibility with Sierra Vwap testing chartbook.
V0.2 :
* Enhance : 4 bands instead of 2
* Change : replaced value extension option by 3 parameters extensions : vwap/band1/band2
V0.1 : Initial release
* New : Continuous/Daily/Weekly/Monthly/Quarterly/Yearly vwap
* New : Standard deviation bands
* New : Previous period value extension
#include "sierrachart.h"
#define DEV_FREE_DLL 0 // 1 for development, 0 when operationnal
const SCString g_StudyVersion   = "V1.4";
const SCString g_VwapName    = "ECIVwap";
const SCString g_VwapAnchorName  = "ECIVwapAnchor";
const SCString g_VwapBracketName= "ECIVwapBracket";
const SCString g_VwapChannelName= "ECIVwapChannel";
const SCString g_ECIVwapStudyDescription =
"<p>The ECIVwap computes Volume Weighted Average Price for Daily/Weekly/Monthly/Quarterly/Yearly periods, and draws extensions of previous periods. Vwap computation tries to be as accurate as possible since using volume at all prices in each bar, and is compatible with Sierra Vwap when using *Base on Underlying Data* option. This is also true for the standard deviation calculation.</p>"
"<p>Developped by Emmanuel Chriqui (aka wwwingman, contact : ecivwap@chriqui.name)</p>";
const SCString g_ECIVwapAnchorStudyDescription =
"<p>The ECIVwapAnchor uses ECIVwap computation algorithm, but the start and end dates are can be set in different ways (manually, automatically, at major reversal points, etc.).</p>"
const SCString g_ECIVwapBracketStudyDescription =
"<p>The ECIVwapBracket draws bracket based on Vwap. A new bracket starts when the last bar breaks out (closes outside) the 2nd standard deviation.</p>"
const SCString g_ECIVwapChannelStudyDescription =
"<p>The ECIVwapChannel uses Vwap computation algorithm, but draws a vwap channel of a user based period number of bars.</p>"
// Sierra DLL name
const SCString g_ScDllName = g_VwapName+g_StudyVersion;
//SCDLLName (g_ScDllName)
// supported period type by ECIVwap
enum ECI_PeriodType
  ECI_PERIOD_TYPE_BAR     = 0,
  ECI_PERIOD_TYPE_DAILY     = 1,
  ECI_PERIOD_TYPE_WEEKLY   = 2,
  ECI_PERIOD_TYPE_MONTHLY   = 3,
  ECI_PERIOD_TYPE_QUARTERLY   = 4,
  ECI_PERIOD_TYPE_YEARLY   = 5,
#define ECI_PERIOD_INPUT_STRINGS "Bar;Daily;Weekly;Monthly;Quarterly;Yearly"
// supported start dates types for ECIVwapAnchor
enum ECI_StartDateType
  ECI_STARTDATETYPE_MANUAL = 0,
  ECI_STARTDATETYPE_HIGHERHIGH = 1,
  ECI_STARTDATETYPE_LOWERLOW = 2,
  ECI_STARTDATETYPE_LASTCLOSEDBAR = 3,
  //WORK IN PROGRESS ECI_STARTDATETYPE_LASTBRACKET = 4
#define ECI_STARTDATETYPE_STRINGS "Manual (mouse anchoring);Start on Higher High;Start on Lower Low;Start on Last Closed Bar"
// supported end dates types for ECIVwapAnchor
enum ECI_EndDateType
  ECI_ENDDATETYPE_CONTINUOUS = 0,
  ECI_ENDDATETYPE_STOP_ON_ENDDATE = 1,
  ECI_ENDDATETYPE_STOP_ON_HIGHERHIGH = 2,
  ECI_ENDDATETYPE_STOP_ON_LOWERLOW = 3,
  ECI_ENDDATETYPE_STOP_ON_LASTCLOSEDBAR = 4,
  ECI_ENDDATETYPE_STOP_ON_STARTBAR = 5,
#define ECI_ENDDATETYPE_STRINGS "Continuous;Stop on End Date;Stop on Higher High;Stop on Lower Low;Stop on Last Closed Bar;Stop on Start Bar"
// misc
#define ECIVWAP_MAIN_COLOR RGB(0,128,255)
#define ECIVWAP_VWAP_COLOR RGB(0,128,255)
#define ECIVWAP_LEVELS_COLOR RGB(0,128,255)
#define ECIVWAP_VPOC_COLOR COLOR_DEEPPINK
// compute bar vwap
// sc : sierra study context
// barIndex : index of bar to compute
// inputOnly : if true, base calculation on main input. otherwise, use input+volume
// barVwap : where result is returned
void ECIVwap_ComputeBarVwap(const SCStudyGraphRef sc, const unsigned int barIndex, const bool inputOnly, SCFloatArrayRef barVwap)
  if ( ! inputOnly )
    unsigned int _barVolume = 0;
    float      _barPriceXVolumeSum = 0;
    const s_VolumeAtPriceV2 *_p_vap;
    int _barPriceInTicks = INT_MIN;
    while (sc.VolumeAtPriceForBars->GetNextHigherVAPElement(barIndex, _barPriceInTicks, &_p_vap))
      _barVolume     += _p_vap->Volume;
      _barPriceXVolumeSum += ((float)_barPriceInTicks * (float)_p_vap->Volume);
    if ( _barVolume != 0 ) // can happen on thin markets, renko charts, gaps etc...
      barVwap[barIndex] = _barPriceXVolumeSum * sc.TickSize / (float)_barVolume;
    else
      barVwap[barIndex] = ( sc.Open[barIndex] + sc.High[barIndex] + sc.Low[barIndex] + sc.Close[barIndex] ) / 4.0f;
  else
// compute period vwap
// periodStartIndex : where vwap starts
// periodEndIndex : where vwap ends
// barVwap : vwap for each bar of period
// vwap : where result is returned
void ECIVwap_ComputePeriodVwap(const SCStudyGraphRef sc, const int periodStartIndex, const unsigned int periodEndIndex, const SCFloatArrayRef barVwap, const bool inputOnly, SCFloatArrayRef vwap)
  if ( ! inputOnly )
    float _periodVolume = 0.f;
    float _periodVwapXVolumeSum = 0.f;
    for (unsigned int _i = periodStartIndex; _i <= periodEndIndex ; _i++)
      _periodVolume += sc.Volume[_i];
      _periodVwapXVolumeSum += (barVwap[_i] * sc.Volume[_i]);
    vwap[periodEndIndex] = _periodVwapXVolumeSum / _periodVolume;
  else
    float _periodHeight = 0.f;
    float _periodVwapXHeightSum = 0.f;
      float _height = sc.High[_i] - sc.Low[_i];
      _periodHeight += _height;
      _periodVwapXHeightSum += (barVwap[_i] * _height);
    vwap[periodEndIndex] = _periodVwapXHeightSum / _periodHeight;
// compute standard deviation levels of vwaps
// vwap : vwap of period
// multiplier : multiplier of standard deviation levels
// tb1-tb4 : where result is returned : top of band number 1..2..3..4
// bb1-bb4 : where result is returned : bottom of band number 1..2..3..4
void ECIVwap_ComputeStddev(const SCStudyGraphRef sc, const unsigned int periodStartIndex, const unsigned int periodEndIndex, const SCFloatArrayRef vwap, const float multiplier, const bool inputOnly,
              SCFloatArrayRef tb1, SCFloatArrayRef bb1,
              SCFloatArrayRef tb2, SCFloatArrayRef bb2,
              SCFloatArrayRef tb3, SCFloatArrayRef bb3,
              SCFloatArrayRef tb4, SCFloatArrayRef bb4 )
  float _offset;
  // compute vwap variance (offset)
  if ( ! inputOnly )
    float _periodVarianceSum = 0.f;
      float _priceInput = sc.Close[_i]-vwap[_i];
      _periodVarianceSum += (_priceInput*_priceInput*sc.Volume[_i]);
    _offset = sqrt(_periodVarianceSum / _periodVolume);
  else
      _periodVarianceSum += (_priceInput*_priceInput*_height);
    _offset = sqrt(_periodVarianceSum / _periodHeight);
  tb1[periodEndIndex] = vwap[periodEndIndex] + 1 * multiplier * _offset;
  bb1[periodEndIndex] = vwap[periodEndIndex] - 1 * multiplier * _offset;
  tb2[periodEndIndex] = vwap[periodEndIndex] + 2 * multiplier * _offset;
  bb2[periodEndIndex] = vwap[periodEndIndex] - 2 * multiplier * _offset;
  tb3[periodEndIndex] = vwap[periodEndIndex] + 3 * multiplier * _offset;
  bb3[periodEndIndex] = vwap[periodEndIndex] - 3 * multiplier * _offset;
  tb4[periodEndIndex] = vwap[periodEndIndex] + 4 * multiplier * _offset;
  bb4[periodEndIndex] = vwap[periodEndIndex] - 4 * multiplier * _offset;
// Check if a new vwap period need to start (session change/day change...)
void ECIVwap_ComputeNewPeriod(const SCStudyGraphRef sc, const ECI_PeriodType periodType, bool& startNewPeriod)
  startNewPeriod = false;
  // bar period is simply the bar vwap, so on each bar we have a new period
  if ( periodType == ECI_PERIOD_TYPE_BAR )
    startNewPeriod = true;
    return;
  if ( sc.Index < 1) // need at least two bars
    return;
  // New period computation is different with daily sessions periods and overnight periods (crossing 00:00)
  // On daily session we look for the daily start session.
  // On overnight sessions wek look the next day start session.
  SCDateTime   currentBarDateTime = sc.BaseDateTimeIn[sc.Index];
  int     currentBarDate = currentBarDateTime.GetDate();
  SCDateTime currentBarTradingStartDateTime = sc.GetStartDateTimeForTradingDate(currentBarDate);
  int      currentBarTradingStartDate = currentBarTradingStartDateTime.GetDate();
  SCDateTime   previousBarDateTime = sc.BaseDateTimeIn[sc.Index-1];
  int      previousBarDate= previousBarDateTime.GetDate();
  // Handle daily sessions
  // Date computation is enough for determining start of period
  if ( currentBarDate == currentBarTradingStartDate )
    int cbPeriod = 0, pbPeriod = 0;  // current and previous bar period (# of day/week/month...)
    switch (periodType)
      case ECI_PERIOD_TYPE_DAILY:
        cbPeriod = currentBarDate; // # of days since December 30, 1899
        pbPeriod = previousBarDate;
        break;
      case ECI_PERIOD_TYPE_WEEKLY:
        cbPeriod = currentBarDate / 7; // # of weeks since December 30, 1899
        pbPeriod = previousBarDate / 7 ;
        break;
      case ECI_PERIOD_TYPE_MONTHLY:
        cbPeriod = currentBarDateTime.GetMonth(); // # of month in the year
        pbPeriod = previousBarDateTime.GetMonth();
        break;
      case ECI_PERIOD_TYPE_QUARTERLY:
        cbPeriod = ((currentBarDateTime.GetMonth()-1) / 3) + 1; // # of quarter in the year,
        pbPeriod = ((previousBarDateTime.GetMonth()-1) / 3) + 1;
        break;
      case ECI_PERIOD_TYPE_YEARLY:
        cbPeriod = currentBarDateTime.GetYear(); // # of year
        pbPeriod = previousBarDateTime.GetYear();
        break;
      default:
        return; // should not be here.
    startNewPeriod = (cbPeriod != pbPeriod);
  else
    // Handle intraday using night sessions
    // We need the DateTime start period for determining start of period
    // and then compare it to the current and previous bars
    SCDateTime   newPeriodBarDateTime = 0;
    if ( periodType == ECI_PERIOD_TYPE_DAILY )
      // new period is tomorrow start session.
      // except when market stopped more than 24h
      if ( currentBarDate - previousBarDate <= 1 )
        newPeriodBarDateTime = sc.GetStartDateTimeForTradingDate(currentBarDate+1);
      else
        newPeriodBarDateTime = currentBarDateTime;
    else if ( periodType == ECI_PERIOD_TYPE_WEEKLY )
      // new period is start of week.
      // Use GetDate that gives # of days since December 1899 to determine week number
      int currentBarWeekStartDate = (currentBarDate/7)*7;
      newPeriodBarDateTime = sc.GetStartDateTimeForTradingDate(currentBarWeekStartDate+1);
    else if ( periodType == ECI_PERIOD_TYPE_MONTHLY )
      // new period is tomorrow month start session
      int yyyy, mm, dd;
      DATE_TO_YMD(currentBarDate+1, yyyy, mm, dd);
      int monthStartDate = YMD_DATE(yyyy, mm, 1);
      newPeriodBarDateTime = sc.GetStartDateTimeForTradingDate(monthStartDate);
    else if ( periodType == ECI_PERIOD_TYPE_QUARTERLY )
      // new period is tomorrow quarter start session
      int yyyy, mm, dd;
      int quarterStartDate = YMD_DATE(yyyy, (((mm-1)/3)*3)+1, 1);
      newPeriodBarDateTime = sc.GetStartDateTimeForTradingDate(quarterStartDate);
    else if ( periodType == ECI_PERIOD_TYPE_YEARLY )
      // new period is tomorrow year start session
      int yyyy, mm, dd;
      int yearStartDate = YMD_DATE(yyyy, 1, 1);
      newPeriodBarDateTime = sc.GetStartDateTimeForTradingDate(yearStartDate);
    else // should not be here
      return;
    startNewPeriod = ( currentBarDateTime >= newPeriodBarDateTime && previousBarDateTime < newPeriodBarDateTime );
// ECIVwap study
SCSFExport scsf_ECIVwap(SCStudyGraphRef sc)
  SCString logMsg;
  // subgraphs
  SCSubgraphRef _vwap   = sc.Subgraph[0];
  SCSubgraphRef _tb1   = sc.Subgraph[1];
  SCSubgraphRef _bb1   = sc.Subgraph[2];
  SCSubgraphRef _tb2   = sc.Subgraph[3];
  SCSubgraphRef _bb2   = sc.Subgraph[4];
  SCSubgraphRef _tb3   = sc.Subgraph[5];
  SCSubgraphRef _bb3   = sc.Subgraph[6];
  SCSubgraphRef _tb4   = sc.Subgraph[7];
  SCSubgraphRef _bb4   = sc.Subgraph[8];
  SCSubgraphRef _extendVwap   = sc.Subgraph[9];
  SCSubgraphRef _extendTB1 = sc.Subgraph[10];
  SCSubgraphRef _extendBB1 = sc.Subgraph[11];
  SCSubgraphRef _extendTB2 = sc.Subgraph[12];
  SCSubgraphRef _extendBB2 = sc.Subgraph[13];
  SCSubgraphRef _extendTB3 = sc.Subgraph[14];
  SCSubgraphRef _extendBB3 = sc.Subgraph[15];
  SCSubgraphRef _extendTB4 = sc.Subgraph[16];
  SCSubgraphRef _extendBB4 = sc.Subgraph[17];
  // input
  SCInputRef _userPeriodType   = sc.Input[0];
  SCInputRef _multiplier = sc.Input[1];
  SCInputRef _toExtendVwap   = sc.Input[2];
  SCInputRef _toExtend1  = sc.Input[3];
  SCInputRef _toExtend2  = sc.Input[4];
  SCInputRef _toExtend3  = sc.Input[5];
  SCInputRef _toExtend4  = sc.Input[6];
  SCInputRef _setAllColors     = sc.Input[7];
  SCInputRef _setAllColorsColor   = sc.Input[8];
  SCInputRef _userInputOnly    = sc.Input[9];
  // Initialize configuration variables
  if (sc.SetDefaults)
    // General
    sc.GraphName     = g_VwapName + g_StudyVersion;
    sc.StudyDescription = g_ECIVwapStudyDescription;
    sc.GraphRegion     = 0;
    // subgraphs
    _vwap.Name       = g_VwapName;
    _vwap.DrawStyle   = DRAWSTYLE_LINE;
    _vwap.PrimaryColor   = ECIVWAP_VWAP_COLOR;
    _tb1.Name       = "Top Band 1 of Vwap Standard Deviation";
    _bb1.Name       = "Bottom Band 1 of Vwap Standard Deviation";
    _tb2.Name       = "Top Band 2 of Vwap Standard Deviation";
    _bb2.Name       = "Bottom Band 2 of Vwap Standard Deviation";
    _tb3.Name       = "Top Band 3 of Vwap Standard Deviation";
    _bb3.Name       = "Bottom Band 3 of Vwap Standard Deviation";
    _tb4.Name       = "Top Band 4 of Vwap Standard Deviation";
    _bb4.Name       = "Bottom Band 4 of Vwap Standard Deviation";
    _tb1.DrawStyle     = _bb1.DrawStyle = DRAWSTYLE_LINE;
    _tb1.LineStyle     = _bb1.LineStyle = LINESTYLE_DOT;
    _tb1.PrimaryColor   = _bb1.PrimaryColor = ECIVWAP_LEVELS_COLOR;
    _tb2.DrawStyle     = DRAWSTYLE_FILLTOP_TRANSPARENT;
    _bb2.DrawStyle    = DRAWSTYLE_FILLBOTTOM_TRANSPARENT;
    _tb2.PrimaryColor   = _bb2.PrimaryColor = ECIVWAP_LEVELS_COLOR;
    _tb3.DrawStyle     = _bb3.DrawStyle = DRAWSTYLE_LINE;
    _tb3.LineStyle     = _bb3.LineStyle = LINESTYLE_DOT;
    _tb3.PrimaryColor   = _bb3.PrimaryColor = ECIVWAP_LEVELS_COLOR;
    _tb4.DrawStyle     = _bb4.DrawStyle = DRAWSTYLE_LINE;
    _tb4.PrimaryColor   = _bb4.PrimaryColor = ECIVWAP_LEVELS_COLOR;
    _extendVwap.Name    = "Vwap extension";
    _extendVwap.DrawStyle  = DRAWSTYLE_DASH;
    _extendVwap.PrimaryColor= _vwap.PrimaryColor;
    _extendTB1.Name      = "Top band 1 extension";
    _extendBB1.Name      = "Bottom band 1 extension";
    _extendTB2.Name      = "Top band 2 extension";
    _extendBB2.Name      = "Bottom band 2 extension";
    _extendTB3.Name      = "Top band 3 extension";
    _extendBB3.Name      = "Bottom band 3 extension";
    _extendTB4.Name      = "Top band 4 extension";
    _extendBB4.Name      = "Bottom band 4 extension";
    _extendTB1.DrawStyle  = _extendBB1.DrawStyle = DRAWSTYLE_DASH;
    _extendTB1.LineStyle  = _extendBB1.LineStyle = LINESTYLE_DOT;
    _extendTB1.PrimaryColor  = _extendBB1.PrimaryColor = ECIVWAP_LEVELS_COLOR;
    _extendTB2.DrawStyle   = DRAWSTYLE_FILLRECTTOP_TRANSPARENT;
    _extendBB2.DrawStyle  = DRAWSTYLE_FILLRECTBOTTOM_TRANSPARENT;
    _extendTB2.PrimaryColor  = _extendBB2.PrimaryColor = ECIVWAP_LEVELS_COLOR;
    _extendTB3.DrawStyle  = _extendBB3.DrawStyle = DRAWSTYLE_DASH;
    _extendTB3.LineStyle  = _extendBB3.LineStyle = LINESTYLE_DOT;
    _extendTB3.PrimaryColor  = _extendBB3.PrimaryColor = ECIVWAP_LEVELS_COLOR;
    _extendTB4.DrawStyle  = _extendBB4.DrawStyle = DRAWSTYLE_DASH;
    _extendTB4.PrimaryColor  = _extendBB4.PrimaryColor = ECIVWAP_LEVELS_COLOR;
    // input
    _userPeriodType.Name  = "Vwap period type";
    _userPeriodType.SetDescription("Vwap period type");
    _userPeriodType.SetCustomInputStrings(ECI_PERIOD_INPUT_STRINGS);
    _userPeriodType.SetCustomInputIndex(1);
    _multiplier.Name   = "Multiplier";
    _multiplier.SetDescription("Standard deviation multiplier");
    _multiplier.SetFloat(0.5);
    _toExtendVwap.Name  = "Extend vwap";
    _toExtendVwap.SetDescription("Extend vwap previous period");
    _toExtendVwap.SetYesNo(1);
    _toExtend1.Name    = "Extend stddev #1";
    _toExtend1.SetDescription("Extend standard deviation number 1");
    _toExtend1.SetYesNo(1);
    _toExtend2.Name    = "Extend stddev #2";
    _toExtend2.SetDescription("Extend standard deviation number 2");
    _toExtend2.SetYesNo(1);
    _toExtend3.Name    = "Extend stddev #3";
    _toExtend3.SetDescription("Extend standard deviation number 3");
    _toExtend3.SetYesNo(1);
    _toExtend4.Name    = "Extend stddev #4";
    _toExtend4.SetDescription("Extend standard deviation number 4");
    _toExtend4.SetYesNo(1);
    _setAllColors.Name = "Set all colors";
    _setAllColors.SetDescription("Set all colors automatically");
    _setAllColors.SetYesNo(0);
    _setAllColorsColor.Name = "Set all colors color";
    _setAllColorsColor.SetDescription("Set all colors automatically color");
    _setAllColorsColor.SetColor(ECIVWAP_MAIN_COLOR);
    _userInputOnly.Name = "Based on input only";
    _userInputOnly.SetDescription("Computation based on input only (no volume)");
    _userInputOnly.SetYesNo(0);
    // misc
    sc.AutoLoop = 1;
    sc.FreeDLL = DEV_FREE_DLL;
    sc.MaintainVolumeAtPriceData = 1; // needed for sc.VolumeAtPriceForBars
    sc.DrawStudyUnderneathMainPriceGraph = 1;
    sc.ScaleRangeType = SCALE_SAMEASREGION;
    return;
  // Do data processing
  SCFloatArrayRef _barVwap     = _vwap.Arrays[0];   // vwap based on all bar prices X volumes
  SCFloatArrayRef PeriodStddev   = _vwap.Arrays[1];    // vwap standard deviation offset
  ECI_PeriodType&  _periodType   = (ECI_PeriodType&)sc.GetPersistentInt(0);  // type of vwap period
  int&       _periodStartIndex = sc.GetPersistentInt(1);  // start of vwap period
  // initialize
  if ( sc.Index == 0 )
    _periodType     = (ECI_PeriodType)_userPeriodType.GetInt();
    _periodStartIndex   = 0;
    // auto coloring
    if ( _setAllColors.GetYesNo() == 1 )
      int _color = _setAllColorsColor.GetColor();
      _vwap.PrimaryColor = _tb1.PrimaryColor = _bb1.PrimaryColor = _tb2.PrimaryColor = _bb2.PrimaryColor = _tb3.PrimaryColor = _bb3.PrimaryColor = _tb4.PrimaryColor = _bb4.PrimaryColor = _extendVwap.PrimaryColor = _extendTB1.PrimaryColor = _extendBB1.PrimaryColor  = _extendTB2.PrimaryColor = _extendBB2.PrimaryColor = _extendTB3.PrimaryColor = _extendBB3.PrimaryColor  = _extendTB4.PrimaryColor = _extendBB4.PrimaryColor = _color;
  // determine if a new vwap period starts
  bool _startNewPeriod = false, _endNewPeriod = false;
  ECIVwap_ComputeNewPeriod(sc, _periodType, _startNewPeriod);
  if ( _startNewPeriod )
    _periodStartIndex   = sc.Index;
  // compute vwap.
  // we start with each bar vwap that is needed on ALL bars.
  // then we compute the period vwap, the standard deviation and the extensions.
  ECIVwap_ComputeBarVwap(sc, sc.Index, _userInputOnly.GetYesNo(), _barVwap);
  ECIVwap_ComputePeriodVwap(sc, _periodStartIndex, sc.Index, _barVwap, _userInputOnly.GetYesNo(), _vwap);
  ECIVwap_ComputeStddev(sc, _periodStartIndex, sc.Index, _vwap, _multiplier.GetFloat(), _userInputOnly.GetYesNo(),
              _tb1, _bb1,
              _tb2, _bb2,
              _tb3, _bb3,
              _tb4, _bb4 );
  // extension...
  if ( sc.Index >= 1 )
      if ( _toExtendVwap.GetYesNo() )
        _extendVwap[sc.Index] = _vwap[sc.Index-1];
      if ( _toExtend1.GetYesNo() )
        _extendTB1[sc.Index] = _tb1[sc.Index-1];
        _extendBB1[sc.Index] = _bb1[sc.Index-1];
      if ( _toExtend2.GetYesNo() )
        _extendTB2[sc.Index] = _tb2[sc.Index-1];
        _extendBB2[sc.Index] = _bb2[sc.Index-1];
      if ( _toExtend3.GetYesNo() )
        _extendTB3[sc.Index] = _tb3[sc.Index-1];
        _extendBB3[sc.Index] = _bb3[sc.Index-1];
      if ( _toExtend4.GetYesNo() )
        _extendTB4[sc.Index] = _tb4[sc.Index-1];
        _extendBB4[sc.Index] = _bb4[sc.Index-1];
    else
        _extendVwap[sc.Index] = _extendVwap[sc.Index-1];
        _extendTB1[sc.Index] = _extendTB1[sc.Index-1];
        _extendBB1[sc.Index] = _extendBB1[sc.Index-1];
        _extendTB2[sc.Index] = _extendTB2[sc.Index-1];
        _extendBB2[sc.Index] = _extendBB2[sc.Index-1];
        _extendTB3[sc.Index] = _extendTB3[sc.Index-1];
        _extendBB3[sc.Index] = _extendBB3[sc.Index-1];
        _extendTB4[sc.Index] = _extendTB4[sc.Index-1];
        _extendBB4[sc.Index] = _extendBB4[sc.Index-1];
  //logMsg.Format("sc.Index=<%d> periodType=<%d>", sc.Index, periodType);
  //sc.AddMessageToLog(logMsg,0);
// ECIVwapAnchor draw vwap and the standard deviation levels
// barIndex : bar index to compute, if needed
// vwap : where vwap results are returned, if needed
// tb1-tb4 : where results are returned if needed : top of band number 1..2..3..4
// bb1-bb4 : where results are returned if needed : bottom of band number 1..2..3..4
// userEndDateType : type of end date chosen by user
// userEndDateTime : date time of end, if needed
// periodEndIndex : where end bar index is returned, if needed and found
void ECIVwapAnchor_DrawVwap(const SCStudyGraphRef sc, const int periodStartIndex, const int barIndex, const bool inputOnly, SCFloatArrayRef barVwap, SCSubgraphRef vwap, const float multiplier,
              SCSubgraphRef tb1, SCSubgraphRef bb1, SCSubgraphRef tb2, SCSubgraphRef bb2,
              SCSubgraphRef tb3, SCSubgraphRef bb3, SCSubgraphRef tb4, SCSubgraphRef bb4,
              const ECI_EndDateType userEndDateType, const SCDateTime userEndDateTime, int& periodEndIndex)
  SCString logMsg;
  if ( barIndex >= periodStartIndex )
    switch ( userEndDateType )
      case ECI_ENDDATETYPE_CONTINUOUS:
        // no end date. draw from periodStartIndex to end of chart
        ECIVwap_ComputeBarVwap(sc, barIndex, inputOnly, barVwap);
        ECIVwap_ComputePeriodVwap(sc, periodStartIndex, barIndex, barVwap, inputOnly, vwap);
        ECIVwap_ComputeStddev(sc, periodStartIndex, barIndex, vwap, multiplier, inputOnly,
                    tb1, bb1,
                    tb2, bb2,
                    tb3, bb3,
                    tb4, bb4 );
        break;
      case ECI_ENDDATETYPE_STOP_ON_ENDDATE:
        // user end date. draw from periodStartIndex to end date.
          SCDateTime currentBarDateTime = sc.BaseDateTimeIn[barIndex];
          SCDateTime previousBarDateTime = (barIndex > 0) ? sc.BaseDateTimeIn[barIndex-1] : currentBarDateTime;
          if ( currentBarDateTime < userEndDateTime )
                        tb1, bb1,
                        tb2, bb2,
                        tb3, bb3,
                        tb4, bb4 );
          else if ( currentBarDateTime > userEndDateTime && previousBarDateTime <= userEndDateTime )
            periodEndIndex = barIndex-1;
        break;
      case ECI_ENDDATETYPE_STOP_ON_HIGHERHIGH:
        // end date on most recent HH. draw from periodStartIndex to HH
          // look for most recent HH
          int hhBarIndex = periodStartIndex;
          for (int i = periodStartIndex; i<= barIndex; i++)
            if ( sc.High > sc.High[hhBarIndex] )
              hhBarIndex = i;
          // bar vwap is needed on all bars after start index
          // continue drawing if we make new highs
          if ( hhBarIndex == barIndex )
            // draw from previous HH to current HH
            int phhBarIndex = periodStartIndex;
            for (int i = periodStartIndex; i<= max(periodStartIndex,hhBarIndex-1); i++)
              if ( sc.High > sc.High[phhBarIndex] )
                phhBarIndex = i;
            for ( int i = phhBarIndex; i <= barIndex ; i++ )
              ECIVwap_ComputePeriodVwap(sc, periodStartIndex, i, barVwap, inputOnly, vwap);
              ECIVwap_ComputeStddev(sc, periodStartIndex, i, vwap, multiplier, inputOnly,
                          tb1, bb1,
                          tb2, bb2,
                          tb3, bb3,
                          tb4, bb4 );
          // set end period bar for extension
          else if ( hhBarIndex == barIndex - 1 )
            periodEndIndex = barIndex - 1;
        break;
      case ECI_ENDDATETYPE_STOP_ON_LOWERLOW:
        // end date on most recent LL. draw from periodStartIndex to LL
          // look for most recent LL
          int llBarIndex = periodStartIndex;
            if ( sc.Low < sc.Low[llBarIndex] )
              llBarIndex = i;
          if ( llBarIndex == barIndex )
            // draw from previous LL to current LL
            int pllBarIndex = periodStartIndex;
            for (int i = periodStartIndex; i<= max(periodStartIndex,llBarIndex-1); i++)
              if ( sc.Low < sc.Low[pllBarIndex] )
                pllBarIndex = i;
            for ( int i = pllBarIndex; i <= barIndex ; i++ )
                          tb1, bb1,
                          tb2, bb2,
                          tb3, bb3,
                          tb4, bb4 );
          else if ( llBarIndex == barIndex - 1 )
        break;
      case ECI_ENDDATETYPE_STOP_ON_LASTCLOSEDBAR:
        // end date on last closed bar. draw from periodStartIndex to end date.
        periodEndIndex = max(periodStartIndex, barIndex-1);
        ECIVwap_ComputeBarVwap(sc, periodEndIndex, inputOnly, barVwap);
        ECIVwap_ComputePeriodVwap(sc, periodStartIndex, periodEndIndex, barVwap, inputOnly, vwap);
        ECIVwap_ComputeStddev(sc, periodStartIndex, periodEndIndex, vwap, multiplier, inputOnly,
                    tb1, bb1,
                    tb2, bb2,
                    tb3, bb3,
                    tb4, bb4 );
        break;
      case ECI_ENDDATETYPE_STOP_ON_STARTBAR:
        // end date on start bar. draw from periodStartIndex to end date.
        if ( barIndex == periodStartIndex )
                      tb1, bb1,
                      tb2, bb2,
                      tb3, bb3,
                      tb4, bb4 );
          periodEndIndex = barIndex;
        break;
      default: // should not get here
        return;
// ECIVwapAnchor draw vwap extensions
void ECIVwapAnchor_DrawVwapExtensions(const SCStudyGraphRef sc, const int periodStartIndex, const int barIndex, const SCSubgraphRef vwap,
                  const SCInputRef toExtendVwap,
                  const SCInputRef toExtend1, const SCInputRef toExtend2, const SCInputRef toExtend3, const SCInputRef toExtend4,
                  const SCSubgraphRef tb1, const SCSubgraphRef bb1, const SCSubgraphRef tb2, const SCSubgraphRef bb2,
                  const SCSubgraphRef tb3, const SCSubgraphRef bb3, const SCSubgraphRef tb4, const SCSubgraphRef bb4,
                  SCSubgraphRef extendVwap,
                  SCSubgraphRef extendTB1, SCSubgraphRef extendBB1, SCSubgraphRef extendTB2, SCSubgraphRef extendBB2,
                  SCSubgraphRef extendTB3, SCSubgraphRef extendBB3, SCSubgraphRef extendTB4, SCSubgraphRef extendBB4,
                  const ECI_EndDateType endDateType, const int periodEndIndex)
  if ( barIndex > periodEndIndex )
    switch ( endDateType )
        if ( periodEndIndex == barIndex-1 )
          if ( toExtendVwap.GetYesNo() )
            extendVwap[barIndex] = extendVwap[barIndex-1] = vwap[barIndex-1];
          if ( toExtend1.GetYesNo() )
            extendTB1[barIndex] = extendTB1[barIndex-1] = tb1[barIndex-1];
            extendBB1[barIndex] = extendBB1[barIndex-1] = bb1[barIndex-1];
          if ( toExtend2.GetYesNo() )
            extendTB2[barIndex] = extendTB2[barIndex-1] = tb2[barIndex-1];
            extendBB2[barIndex] = extendBB2[barIndex-1] = bb2[barIndex-1];
          if ( toExtend3.GetYesNo() )
            extendTB3[barIndex] = extendTB3[barIndex-1] = tb3[barIndex-1];
            extendBB3[barIndex] = extendBB3[barIndex-1] = bb3[barIndex-1];
          if ( toExtend4.GetYesNo() )
            extendTB4[barIndex] = extendTB4[barIndex-1] = tb4[barIndex-1];
            extendBB4[barIndex] = extendBB4[barIndex-1] = bb4[barIndex-1];
        else
            extendVwap[barIndex]   = extendVwap[barIndex-1];
            extendTB1[barIndex]   = extendTB1[barIndex-1];
            extendBB1[barIndex]   = extendBB1[barIndex-1];
            extendTB2[barIndex]   = extendTB2[barIndex-1];
            extendBB2[barIndex]   = extendBB2[barIndex-1];
            extendTB3[barIndex]   = extendTB3[barIndex-1];
            extendBB3[barIndex]   = extendBB3[barIndex-1];
            extendTB4[barIndex]   = extendTB4[barIndex-1];
            extendBB4[barIndex]   = extendBB4[barIndex-1];
        break;
      default:
        break;
// ECIVwapAnchor study
SCSFExport scsf_ECIVwapAnchor(SCStudyGraphRef sc)
  SCString logMsg;
  // subgraphs
  // input
  SCInputRef _multiplier   = sc.Input[0];
  SCInputRef _toExtendVwap= sc.Input[1];
  SCInputRef _toExtend1  = sc.Input[2];
  SCInputRef _toExtend2  = sc.Input[3];
  SCInputRef _toExtend3  = sc.Input[4];
  SCInputRef _toExtend4  = sc.Input[5];
  SCInputRef _userStartDateType   = sc.Input[6];
  SCInputRef _userEndDateType   = sc.Input[7];
  SCInputRef _userEndDate     = sc.Input[8];
  SCInputRef _setAllColors     = sc.Input[9];
  SCInputRef _setAllColorsColor   = sc.Input[10];
  SCInputRef _userInputOnly    = sc.Input[11];
  SCInputRef _hiddenStartIndex   = sc.Input[12]; // just for saving
  int&         _periodStartIndex = sc.GetPersistentInt(0);  // start bar index of vwap
  ECI_StartDateType&   _startDateType   = (ECI_StartDateType&)sc.GetPersistentInt(1); // start date tyype
  int&         _periodEndIndex = sc.GetPersistentInt(2);  // end bar index of vwap
  ECI_EndDateType&   _endDateType   = (ECI_EndDateType&)sc.GetPersistentInt(3); // vwap period type
  int&         _menuID = sc.GetPersistentInt(4);
  int&        _lastBracketIndex = sc.GetPersistentInt(5);
  if (sc.SetDefaults)
    // General
    sc.GraphName     = g_VwapAnchorName + g_StudyVersion;
    sc.StudyDescription = g_ECIVwapAnchorStudyDescription;
    sc.GraphRegion     = 0;
    // subgraphs
    _vwap.Name       = g_VwapAnchorName;
    _vwap.PrimaryColor   = RGB(128,0,128);
    _tb1.DrawStyle     = DRAWSTYLE_LINE;
    _tb1.LineStyle    = LINESTYLE_DOT;
    _tb1.PrimaryColor   = ECIVWAP_MAIN_COLOR;
    _bb1.PrimaryColor   = ECIVWAP_MAIN_COLOR;
    _tb2.PrimaryColor   = ECIVWAP_MAIN_COLOR;
    _bb2.PrimaryColor   = ECIVWAP_MAIN_COLOR;
    _tb3.DrawStyle     = DRAWSTYLE_LINE;
    _tb3.LineStyle    = LINESTYLE_DOT;
    _tb3.PrimaryColor   = ECIVWAP_MAIN_COLOR;
    _bb3.PrimaryColor   = ECIVWAP_MAIN_COLOR;
    _tb4.DrawStyle     = DRAWSTYLE_LINE;
    _tb4.PrimaryColor   = ECIVWAP_MAIN_COLOR;
    _bb4.PrimaryColor   = ECIVWAP_MAIN_COLOR;
    _extendVwap.DrawStyle  = DRAWSTYLE_LINE;
    _extendVwap.LineStyle  = LINESTYLE_DASH;
    _extendTB1.DrawStyle  = _tb1.DrawStyle;
    _extendTB1.LineStyle  = _tb1.LineStyle;
    _extendTB1.PrimaryColor  = _tb1.PrimaryColor;
    _extendBB1.DrawStyle  = _bb1.DrawStyle;
    _extendBB1.LineStyle  = _bb1.LineStyle;
    _extendBB1.PrimaryColor  = _bb1.PrimaryColor;
    _extendTB2.DrawStyle  = _tb2.DrawStyle;
    _extendTB2.LineStyle  = _tb2.LineStyle;
    _extendTB2.PrimaryColor  = _tb2.PrimaryColor;
    _extendBB2.DrawStyle  = _bb2.DrawStyle;
    _extendBB2.LineStyle  = _bb2.LineStyle;
    _extendBB2.PrimaryColor  = _bb2.PrimaryColor;
    _extendTB3.DrawStyle  = _tb3.DrawStyle;
    _extendTB3.LineStyle  = _tb3.LineStyle;
    _extendTB3.PrimaryColor  = _tb3.PrimaryColor;
    _extendBB3.DrawStyle  = _bb3.DrawStyle;
    _extendBB3.LineStyle  = _bb3.LineStyle;
    _extendBB3.PrimaryColor  = _bb3.PrimaryColor;
    _extendTB4.DrawStyle  = _tb4.DrawStyle;
    _extendTB4.LineStyle  = _tb4.LineStyle;
    _extendTB4.PrimaryColor  = _tb4.PrimaryColor;
    _extendBB4.DrawStyle  = _bb4.DrawStyle;
    _extendBB4.LineStyle  = _bb4.LineStyle;
    _extendBB4.PrimaryColor  = _bb4.PrimaryColor;
    // input
    _multiplier.SetFloat(0.5f);
    _userStartDateType.Name = "Start type";
    _userStartDateType.SetDescription("Start date type");
    _userStartDateType.SetCustomInputStrings(ECI_STARTDATETYPE_STRINGS);
    _userStartDateType.SetCustomInputIndex(0);
    _userEndDateType.Name = "End type";
    _userEndDateType.SetDescription("End date type");
    _userEndDateType.SetCustomInputStrings(ECI_ENDDATETYPE_STRINGS);
    _userEndDateType.SetCustomInputIndex(0);
    _userEndDate.Name  = "End date";
    _userEndDate.SetDescription("End date, if end type is stop on end date chosen");
    _userEndDate.SetDateTime(0);
    //XXHiddenStartIndex.Name = "Hidden start index"; // used to store start index
    _hiddenStartIndex.SetInt(INT_MAX);
    // misc
    sc.AutoLoop = 1;
    //MenuID = 0;
    return;
  SCFloatArrayRef _barVwap     = _vwap.Arrays[0];   // bar vwap, based on all volume per price in the bar
  SCFloatArrayRef _stddevOffset   = _vwap.Arrays[1];    // vwap standard deviation offset
  // initilize
    _startDateType = (ECI_StartDateType)_userStartDateType.GetInt();
    // set period start, if available
    sc.RemoveACSChartShortcutMenuItem(sc.ChartNumber, _menuID);
    switch ( _startDateType )
      case ECI_STARTDATETYPE_MANUAL:
          // add chart shortcut menu item
          SCString _menuName;
          _menuName.Format("Anchor Vwap <%d>", sc.StudyGraphInstanceID);
          //if (_menuID <= 0) // when duplicating chart _menuID is not at 0
            _menuID = sc.AddACSChartShortcutMenuItem(sc.ChartNumber, _menuName);
          if (_menuID < 0)
            sc.AddMessageToLog("Failed adding Menu Item", 1);
          _periodStartIndex = _hiddenStartIndex.GetInt();
        break;
/*      WORK IN PROGRESS ...
      case ECI_STARTDATETYPE_LASTBRACKET:
        break;
      default:
        _periodStartIndex = INT_MAX;
        break;
    _higherHigh = 0.f;
    _lowerLow = FLT_MAX;
    // set end period, if available
    _endDateType = (ECI_EndDateType)_userEndDateType.GetInt();
    _periodEndIndex = INT_MIN;
    // auto coloring
  // Update start period if needed
  bool _needNewStart = false;
      if (sc.MenuEventID != 0 && sc.MenuEventID == _menuID)
        _needNewStart = true;
        _periodStartIndex = sc.ActiveToolIndex;
        _hiddenStartIndex.SetInt(_periodStartIndex);
      if (sc.LastCallToFunction)
        // be sure to remove the menu command when study is removed
        return;
      break;
    case ECI_STARTDATETYPE_HIGHERHIGH:
      if ( sc.High[sc.Index] > _higherHigh && _periodStartIndex != sc.Index )
        _higherHigh = sc.High[sc.Index];
      break;
    case ECI_STARTDATETYPE_LOWERLOW:
      if ( sc.Low[sc.Index] < _lowerLow && _periodStartIndex != sc.Index )
        _lowerLow = sc.Low[sc.Index];
      break;
    case ECI_STARTDATETYPE_LASTCLOSEDBAR:
      if ( _periodStartIndex != sc.Index-1 )
        _periodStartIndex = max(0, sc.Index-1);
      break;
/*    TODO : WORK IN PROGRESS...
        float _lastPrice = sc.Close[max(sc.Index-1,0)];
        if ( _lastPrice <= _tb4[_periodStartIndex] && _lastPrice >= _bb4[_periodStartIndex] )
          // nothing...
          logMsg.Format("sc.Index=<%d> _periodStartIndex=<%d>", sc.Index, _periodStartIndex);
        else
          //_needNewStart = true;
          for (int _i=sc.Index-1 ; _i >= 0 ; _i-- )
            if ( _lastPrice <= _tb2[_i] && _lastPrice >= _bb2[_i] )
              _periodStartIndex = _i;
              break;
      break;
    default: // should not be here
      return;
  // erase all previous vwap/stddev/extensions values if new period set
  if ( _needNewStart )
    for (int _i = 0 ; _i <= sc.Index; _i++)
      _vwap[_i] = _tb1[_i] = _bb1[_i] = _tb2[_i] = _bb2[_i] = _tb3[_i] = _bb3[_i] = _tb4[_i] = _bb4[_i] = 0.f;
      _extendVwap[_i] = _extendTB1[_i] = _extendBB1[_i] = _extendTB2[_i] = _extendBB2[_i] = _extendTB3[_i] = _extendBB3[_i] = _extendTB4[_i] = _extendBB4[_i] = 0.f;
  // draw Vwap and extensions
  int _startIndex = _needNewStart ? 0 : sc.Index;
  for (int _i = _startIndex; _i <= sc.Index; _i++)
    ECIVwapAnchor_DrawVwap(sc, _periodStartIndex, _i, _userInputOnly.GetYesNo(), _barVwap, _vwap, _multiplier.GetFloat(),
                _tb1, _bb1, _tb2, _bb2, _tb3, _bb3, _tb4, _bb4,
                _endDateType, _userEndDate.GetDateTime(), _periodEndIndex);
    ECIVwapAnchor_DrawVwapExtensions(sc, _periodStartIndex, _i, _vwap,
                    _toExtendVwap,
                    _toExtend1, _toExtend2, _toExtend3, _toExtend4,
                    _extendVwap,_extendTB1, _extendBB1, _extendTB2, _extendBB2, _extendTB3, _extendBB3, _extendTB4, _extendBB4,
                    _endDateType, _periodEndIndex);
// ECIVwapBracket study
SCSFExport scsf_ECIVwapBracket(SCStudyGraphRef sc)
  SCString logMsg;
  // subgraphs
  // input
  if (sc.SetDefaults)
    // General
    sc.GraphName     = g_VwapBracketName + g_StudyVersion;
    sc.StudyDescription = g_ECIVwapBracketStudyDescription;
    sc.GraphRegion     = 0;
    // subgraphs
    _vwap.Name       = g_VwapBracketName;
    _vwap.DrawStyle   = DRAWSTYLE_DASH;
    _tb1.DrawStyle     = _bb1.DrawStyle = DRAWSTYLE_DASH;
    _tb1.PrimaryColor   = _bb1.PrimaryColor = ECIVWAP_MAIN_COLOR;
    _tb2.DrawStyle     = DRAWSTYLE_FILLRECTTOP_TRANSPARENT;
    _bb2.DrawStyle     = DRAWSTYLE_FILLRECTBOTTOM_TRANSPARENT;
    _tb2.PrimaryColor   = _bb2.PrimaryColor = ECIVWAP_MAIN_COLOR;
    _tb3.DrawStyle     = _bb3.DrawStyle = DRAWSTYLE_DASH;
    _tb3.PrimaryColor   = _bb3.PrimaryColor = ECIVWAP_MAIN_COLOR;
    _tb4.DrawStyle     = _bb4.DrawStyle = DRAWSTYLE_DASH;
    _tb4.PrimaryColor   = _bb4.PrimaryColor = ECIVWAP_MAIN_COLOR;
    // input
    // misc
    sc.AutoLoop = 1;
    return;
  SCFloatArrayRef _hVwap       = _vwap.Arrays[0];   // vwap of each bar
  SCFloatArrayRef _stddevOffset   = _vwap.Arrays[1];  // standard deviation offset of vwap
  SCFloatArrayRef _hTB1       = _vwap.Arrays[3];  //
  SCFloatArrayRef _hBB1       = _vwap.Arrays[4];  //
  SCFloatArrayRef _hTB2       = _vwap.Arrays[5];  //
  SCFloatArrayRef _hBB2       = _vwap.Arrays[6];  //
  SCFloatArrayRef _hTB3       = _vwap.Arrays[7];  //
  SCFloatArrayRef _hBB3       = _vwap.Arrays[8];  //
  SCFloatArrayRef _hTB4       = _vwap.Arrays[9];  //
  SCFloatArrayRef _hBB4       = _vwap.Arrays[10];  //
  // initilize
    // auto coloring
                 _tb3.PrimaryColor = _bb3.PrimaryColor = _tb4.PrimaryColor = _bb4.PrimaryColor = _color;
  // compute a hidden vwap and stddev for each bar
  ECIVwap_ComputeBarVwap(sc, sc.Index, _userInputOnly.GetYesNo(), _hVwap);
  ECIVwap_ComputePeriodVwap(sc, sc.Index, sc.Index, _hVwap, _userInputOnly.GetYesNo(), _hVwap);
  ECIVwap_ComputeStddev(sc, sc.Index, sc.Index, _hVwap, _multiplier.GetFloat(), _userInputOnly.GetYesNo(),
              _hTB1, _hBB1,
              _hTB2, _hBB2,
              _hTB3, _hBB3,
              _hTB4, _hBB4);
  // draw last bracket value
  if ( sc.Index > 0 )
    float _lastPrice = sc.Close[sc.Index-1];
    if ( _lastPrice >= _hBB4[_periodStartIndex] && _lastPrice <= _hTB4[_periodStartIndex] )
      // nothing to do
    else
      for (int _i=sc.Index-1; _i >= 0; _i-- )
        if ( _lastPrice >= _hBB4[_i] && _lastPrice <= _hTB4[_i] )
          break;
  _vwap[sc.Index] = _hVwap[_periodStartIndex];
  _tb1[sc.Index] = _hTB1[_periodStartIndex];
  _bb1[sc.Index] = _hBB1[_periodStartIndex];
  _tb2[sc.Index] = _hTB2[_periodStartIndex];
  _bb2[sc.Index] = _hBB2[_periodStartIndex];
  _tb3[sc.Index] = _hTB3[_periodStartIndex];
  _bb3[sc.Index] = _hBB3[_periodStartIndex];
  _tb4[sc.Index] = _hTB4[_periodStartIndex];
  _bb4[sc.Index] = _hBB4[_periodStartIndex];
// compute vpoc in channel
// vpoc : where vpoc is returned
void ECIVwap_ComputeChannelVPOC(SCStudyGraphRef sc, unsigned int periodStartIndex, SCSubgraphRef vpoc)
  // compute vpoc
  // get highest and lowest of period
  int  _highInTicks = 0, _lowInTicks = INT_MAX;
  for (unsigned int _barIndex = periodStartIndex ; _barIndex <= sc.Index ; _barIndex++)
    int _barHighInTicks, _barLowInTicks;
    if ( ! sc.VolumeAtPriceForBars->GetHighAndLowPriceTicksForBarIndex(_barIndex, _barHighInTicks, _barLowInTicks) )
      sc.AddMessageToLog("Error on sc.VolumeAtPriceForBars->GetHighAndLowPriceTicksForBarIndex",0);
      return;
    if ( _barHighInTicks > _highInTicks )
      _highInTicks = _barHighInTicks;
    if ( _barLowInTicks < _lowInTicks )
      _lowInTicks = _barLowInTicks;
  // compute vpoc.
  // for each price, make the sum on all bars period
  unsigned long _maxVolume = 0;
  int       _maxVolumePriceInTicks;
  for (int _priceInTicks =_lowInTicks ; _priceInTicks <= _highInTicks ; _priceInTicks++ )
    unsigned long   _sumVolume = 0;
        _sumVolume += _p_vap->Volume;
    if ( _sumVolume > _maxVolume )
      _maxVolume = _sumVolume;
      _maxVolumePriceInTicks = _priceInTicks;
  vpoc[sc.Index] = (float)_maxVolumePriceInTicks * sc.TickSize;
// ECIVwapChannel study
SCSFExport scsf_ECIVwapChannel(SCStudyGraphRef sc)
  SCString logMsg;
  // subgraphs
  SCSubgraphRef _vpoc = sc.Subgraph[9];
  // input
  SCInputRef _period     = sc.Input[0];
  SCInputRef _setAllColors     = sc.Input[2];
  SCInputRef _setAllColorsColor   = sc.Input[3];
  SCInputRef _userInputOnly    = sc.Input[4];
  SCInputRef _computeVpoc  = sc.Input[5];
  if (sc.SetDefaults)
    // General
    sc.GraphName     = g_VwapChannelName + g_StudyVersion;
    sc.StudyDescription = g_ECIVwapChannelStudyDescription;
    sc.GraphRegion     = 0;
    // subgraphs
    _vwap.Name       = g_VwapChannelName;
    _vwap.PrimaryColor   = ECIVWAP_MAIN_COLOR;
    _vwap.LineWidth    = 2;
    _vpoc.Name       = "Vpoc";
    _vpoc.DrawStyle   = DRAWSTYLE_LINE;
    _vpoc.PrimaryColor   = ECIVWAP_VPOC_COLOR;
    _vpoc.LineWidth    = 2;
    // input
    _period.Name    = "Period";
    _period.SetDescription("Vwap channel period");
    _period.SetInt(50);
    _computeVpoc.Name = "Compute VPOC (experimental)";
    _computeVpoc.SetYesNo(0);
    // misc
    sc.AutoLoop = 1;
    return;
  // initilize
  int _periodStartIndex    = max(sc.Index - _period.GetInt() + 1, 0);
    // auto coloring
              _tb1, _bb1,
              _tb2, _bb2,
              _tb3, _bb3,
              _tb4, _bb4 );
  // compute vpoc
  if ( _computeVpoc.GetYesNo() == 1 )
    ECIVwap_ComputeChannelVPOC(sc, _periodStartIndex, _vpoc);
  //sc.AddMessageToLog(logMsg,0); */
[2020-04-05 17:52:01]
Hi
I made the required changes for compiling properly with latest Sierra code changes.
It is enclosed-by as ECIVwap V1.5.
I will also update Sierra support for using this code instead of the previous one.
Have a good week.
-- W
attachmentECIVwap.cpp - Attached On 2020-04-05 17:51:11 UTC - Size: 61.93 KB - 877 views
