Date/Time: Mon, 20 Jan 2025 17:01:07 +0000
Missing CR/LF in Message Log files since v.1771
View Count: 871
[2018-07-02 14:48:38] |
User924791 - Posts: 12 |
The message log text files have lost their line breaks, i.e., the entire text is contained in a single line. The issue continues in v. 1775.
[2018-07-02 16:34:34] |
This will be solved in the next release.
