Date/Time: Mon, 20 Jan 2025 17:01:03 +0000
VpB chart not respecting
View Count: 645
[2018-07-01 17:04:24]
User686802 - Posts: 69
Hi, please refer to attached screen1 and screen2 images.
In screen1, I hightlight Yellow "One Period at End Fixed Time Length" for period "Weeks"
I only made ONE SINGLE change to screen2, to "One Period Most Recent Period Start to End" for period "Weeks"
Notice, on the screenshots that with ONLY this one parameter change, the screen2 "Bad" was that it took the startime outside of the normal 9:30am to 16:29pm that was set in "Use Different Start Time".
I had the "Draw Outline Enclosing Bar" set ON to show you that in screen1 it enclosed only the day's 9:30am to 16:29pm data which is what I want, labeled as "Good".
But in screen2, it enclosed data outside of 9:30am to 16:29pm, which I labeled in the image as "Bad". It took that data before Monday 9:30am open, to that data came from the overnight Sunday session high.
In summary, what I am looking for you fix is that for screen2, with the "One Period Most Recent Period Start to End" for period "Weeks", it should respect the "Use Different Start Time" so in the screen2 image should show the "Draw Outline Enclosing Bar" away from the "Bad" and back to where I marked as "Good", which is how the screen1 setting was at.
Hope it is clear, thanks,
B
imagescreen1.JPG / V - Attached On 2018-07-01 16:52:03 UTC - Size: 139.94 KB - 315 views
imagescreen2.JPG / V - Attached On 2018-07-01 16:52:15 UTC - Size: 147.26 KB - 246 views
[2018-07-02 22:18:28]
Have you looked at the screenshots and review the error I open the case with?
[2018-07-03 06:50:17]
Your post is hard to understand. As a matter of policy we are not going to struggle to understand it.
The way we want to approach this is for you is to have you describe simply, one simple volume by price configuration that you require that you are having a problem with and we will prepare an example Chartbook to do that, assuming it is even supported.
Date Time Of Last Edit: 2018-07-03 07:45:53
