Date/Time: Mon, 20 Jan 2025 20:53:33 +0000
Customise control bars -
View Count: 674
[2018-07-01 11:29:13] |
samual sprat - Posts: 343 |
Hi, The add blank function's space that's created between buttons has reduced significantly since 1765 at some point. The space is now too small and doesn't create a large enough separation between buttons to be easily visible. Thanks S |
[2018-07-01 11:35:38] |
We are looking into this.
[2018-07-11 07:32:40] |
Any update?
[2018-07-11 16:21:28] |
Use the current version which is now 1781.
