Date/Time: Mon, 20 Jan 2025 16:54:38 +0000
[User Discussion] - Symbol Lists
View Count: 1192
[2018-06-30 19:08:23]
Litz - Posts: 131
attached a few symbol lists spx500 nas100 and dow30 to be used in the associated watch list sc scan function fwiw. other lists can be downloaded from www.barchart.com save as .symbollist and place in data folder
Date Time Of Last Edit: 2018-06-30 21:49:14
attachment500.symbollist - Attached On 2018-06-30 19:07:00 UTC - Size: 2.5 KB - 391 views
attachmentNASDAQ 100.SYMBOLLIST - Attached On 2018-06-30 19:07:28 UTC - Size: 546 B - 270 views
attachmentdow30.SymbolList - Attached On 2018-06-30 19:14:32 UTC - Size: 141 B - 279 views
[2018-06-30 21:40:56]
Litz - Posts: 131
Here is another High power rated stocks as of yesterday very strong
Date Time Of Last Edit: 2018-06-30 21:49:37
attachmentPowerstocks july 2018.symbollist - Attached On 2018-06-30 21:40:43 UTC - Size: 2.18 KB - 440 views
[2018-06-30 21:45:44]
Steve - Posts: 16
You need to modify the attachments and set them "public" because currently they are set to "private".
[2018-06-30 21:50:07]
Litz - Posts: 131
thx done
