Date/Time: Mon, 20 Jan 2025 17:04:22 +0000
Trading DOM
View Count: 825
[2018-06-29 20:15:55]
User884307 - Posts: 173
Hi
If I have 2(or more) instances of the trading DOM windows open, and I for example clear the "recent volume", what setting do I need to alter to stop it globally resetting the volume in all the DOM's
It was working fine and resetting independently on each DOM but all of a sudden it stopped doing this and started restting all volumes???
But confused as to what changed as I havent changed anything?
Thanks in advance
[2018-06-29 20:38:02]
There has never been any way to prevent this. If you are resetting the recent traded volume for a particular symbol, it simply is going to affect all charts and trading DOM windows for that particular symbol.
[2018-06-29 21:08:24]
hi
just been looking at this, it doesn't globally reset in replay mode, only live market?
Could this be possible to work in live market also?
Thankyou 👍
Date Time Of Last Edit: 2018-06-29 21:08:44
[2018-06-30 08:35:54]
Yes actually that is true. There is no global reset with chart replays.
No.
Date Time Of Last Edit: 2018-06-30 08:36:52
[2018-06-30 10:02:01]
Is this something that isn't possible or just a No
Cheers 👍👍
[2018-06-30 16:14:23]
A definitive absolute no. Anything is possible but it is with absolute certainty we are not going to do this.
Date Time Of Last Edit: 2018-06-30 16:28:12
[2018-06-30 17:12:48]
Ok that's not a problem, however any reason for the unfriendly response? not sure if I missed something?
Cheers
[2018-06-30 19:54:29]
We are very busy and we have to be very clear in order to bring a thread to a close and make our position abundantly clear so there is no confusion. And so there is no reliance upon us for something that is never going to come.
Date Time Of Last Edit: 2018-06-30 19:55:10
