Date/Time: Mon, 20 Jan 2025 16:49:05 +0000
auto trading question
View Count: 694
[2018-06-29 20:11:46] |
Glenn Infinity - Posts: 103 |
Is there a way to auto trade just one chart if you have two up in a chart-book? Both charts are auto tradable charts. If I have auto trading enabled checked they both trade. is there a way to auto trade one but not the other. Like trade YM chart but not the ES chart |
[2018-06-30 09:05:23] |
Auto trading can be enabled per chart so this is a way to control this. Refer to this particular setting: Trade Menu: Auto Trading Enabled - Chart (Trade menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
