Date/Time: Mon, 20 Jan 2025 16:56:42 +0000
Unable to Output Study Data to Spreadsheet Study
View Count: 1400
[2018-06-29 15:32:49]
TapeReader - Posts: 89
Something has gone awry with my ability to output data to a spreadsheet study.
In the attached example RSI study data is outputted, however, there is no RSI study on the chart.
However, there is a Zig-Zag study and none of this study's output is not written to the .scss file (Note - Additional Output for Spreadsheets = Yes).
I have tried a bunch of permutations with different machines, different spreadsheet studies, different .scss files and different sheets in .scss files, but the behavior remains the same.
I have revved to build 1772 and the behavior remains the same.
Can SC Engineering open the attached chartbook and scss file to see of the behavior is consistent on your side of the fence?
Thanks,
C
attachmentZZ Output.Cht - Attached On 2018-06-29 15:30:18 UTC - Size: 39.25 KB - 365 views
Private File
[2018-06-29 21:41:37]
We took a look and you did not have the option for Include in Spreadsheet selected for the Zig Zag study. This is necessary, even if you select Yes to Additional Output for Spreadsheets.
As to the RSI information, this spreadsheet must have been used previously with that study included in it. Although once you correct the issue with the Zig Zag, it will overwrite the columns from the RSI that were there.
[2018-07-01 13:38:04]
I am now able to output the SG.1 From Zig-Zag, however, the cells in the remaining subgraphs columns in the .scss file (SG.2 - SG.9) are blank.
Any insights here?
attachmentZZ Output_02.Cht - Attached On 2018-07-01 13:37:23 UTC - Size: 39.25 KB - 258 views
attachmentTemp.scss - Attached On 2018-07-01 13:37:28 UTC - Size: 137.34 KB - 293 views
[2018-07-01 14:00:23]
Update....I see now that there are multiple check-boxes in the Zig-Zag study for 'Include in Spreadsheet'.
One is on the 'Settings and Input' tab and one is exposed on the 'Subgraphs' tab for each subgraph.
I am now able to output the data.
All's good.
This issue is closed.
Date Time Of Last Edit: 2018-07-01 14:42:56
[2018-07-01 14:34:28]
For future reference here is the relevant documentation:
Using the Spreadsheet Study: Solving Study Not Displaying On Spreadsheet Sheet
